It is currently Wed Jul 18, 2018 1:04 am
PostPosted: Wed Jan 10, 2018 6:36 am
I am wondering about the potential sonic improvements that could be had from hard wiring certain components together thereby eliminating or reducing negative effects of binding posts and connectors. For example, remove binding posts and hard wire cables to crossover of speakers and do the same at the amp end. Same thing for the amp/pre and possibly the analogue input. Could also directly connect power cords at the component end, but for electrical code reasons, no the wall of course.
I understand the potential "convenience" and practical implications (i.e. having components tethered together), but if one is content with the cables one is using, other than a couple hours work, all would be completely reversible. I know this is a bit "out there" but I am wondering if anyone has done something similar and to what effect. Cheers
PostPosted: Wed Jan 10, 2018 6:45 am
I've done all that you are suggesting.....on Rogers LS3,5a's and 2 Dvna Stereo 70 power amps.
Quite honestly, to my ears, it made no discernible difference.
YMMV, as usual.
Cheers, dl Sol
-- 10 Jan 2018 14:45 --
I've done all that you are suggesting.....on Rogers LS3/5a's and 2 Dvna Stereo 70 power amps.
YMMV, as usual.
Cheers, del Sol
PostPosted: Wed Jan 10, 2018 7:20 am
If you decide to this type of attachment to your x overs and solder your connections . You may want to use a good solder. I suggest using Cardas Silver solder. Its considered superior to regular solder with better connectivity . You may as well try to get the best contact means or your just wasting your time going this route.
PostPosted: Wed Jan 10, 2018 8:58 am
If you're using the solder to complete the connection....... you're doing it wrong!
Some people like the taste of smokey whiskey, others think that tea's too strong!!
Even if you've tried it, consider the six blind men describing the elephant before offering your opinion!
PostPosted: Wed Jan 10, 2018 9:26 am
Care to elaborate and contribute to the discussion or simply throw stones :roll:
PostPosted: Wed Jan 10, 2018 10:07 am
While not quite "hard wired", this was a successful step in that direction. I bypassed the terminals and a couple feet of internal wires in an old set of speakers and, to my ears, this made a noticeable improvement.
http://www.canuckaudiomart.com/forum/viewtopic.php?f=6&t=46203
PostPosted: Wed Jan 10, 2018 10:42 am
I believe he means connection is made wire to wire . Solder is just there to keep
them together .
PostPosted: Wed Jan 10, 2018 12:04 pm
One of my turntables, an older Dual, has several contact points from cartridge tags to RCA terminations. Tags to wires to a contact pad in the headshell to the fine wires in the tonearm to a junction box in the table that has connectors to link the RCAs to the tonearm wire... I changed the RCAs out and rewired them directly to the tonearm cable inside, bypassing the junction box. This made a huge improvement. I used solder. I want to bypass the headshell and pressure pads to go directly to the cartridge. But, I haven't gone that far yet. This is likely due to newer, and better quality wires.
I would imagine having wires from your amp to your speakers crossover should give minor improvements if done correctly. Realize that the back plate of most speakers probably properly seals the enclosure. To go bare wire, you'd probably have to drill holes, or remove the back plate, etc. I'd imagine tonearm wires would make more improvement, what with the smaller voltages and that taking place before the amplification. To that same end, RCAs would be good to direct wire. Doesn't necessarily mean you have to use solder for the speaker internals. You could likely use some sort of cinch connector or snap connector.
I'd be interested to see this, as I've read majority of common hifi speakers use rather average, run of the mill wires internally. If you spend, say, 1/4 of the speaker cost on speaker cables, it'd make sense the wires match internally. My Focal 706v are connected using Kimber 4PR... I'd like to use 4PR internally, as these have cheap looking wire internally!
Hope this helps and isnt' much of a rant!
PostPosted: Wed Jan 10, 2018 2:47 pm
Basic soldering techniques. One makes sure that there is a solid mechanical connection, then that is held in place with the solder. The mechanical connection, in the case of a current carrying circuit, is the conduit. The solder just makes sure that it (connection) doesn't move or break. Silver or not, the solder has no other purpose! :roll: :roll: :roll:
them together .
I couldn't say it better myself! :lol:
PostPosted: Wed Jan 10, 2018 5:30 pm
That's very old school thinking, and frankly not really all that relevant with modern gear. In PCB construction, there is very rarely a solid mechanical connection, only a wire shoved through a hole, and the solder makes the connection from the wire to the pad.
Cheers, Dave
PostPosted: Wed Jan 10, 2018 5:47 pm
Yes you want to make sure there is good metal to metal contact before
solder is added. In other words, do not bridge a connection with solder.
Many tube builders prefer P to P wiring over PC boards.
PostPosted: Wed Jan 10, 2018 6:22 pm
Yes, that's true...
But is it because point to point costs nothing (beyond the extra labor)? While designing and manufacturing a PCB is more expensive and requires additional skills?
I've used point to point a lot with solid state designs as well. For experiments or one-offs, the effort to build a PCB is often had to justify, even though I have everything required to build them in my basement.
Dave
PostPosted: Thu Jan 11, 2018 6:11 am
If you mount a piece on a PCB do you not give the leads a quick bend to hold the component in place until you apply the solder? Ergo.... a mechanical connection. If you use the solder to create the bond, you are creating 2 connections to replace 1,.... which is opposite to the purpose of this exercise, and adds another uncontrolled factor to the circuit, (minuscule though it may be). Do and believe what you want, ......... I'll do it my way, and stop trying to help.
PostPosted: Thu Jan 11, 2018 7:02 am
I once hardwired a Rega Planar 3 to a Rotel RQ 970 BX phono which I had a tech mount an ALPs volume pot on the front to direct drive the amp. It was in turn hardwired to an Audire Model 2 amp. The speaker cables were hardwired at the speaker end to a pair of Spica TC50i's. That was a very nice revealing system and removing 3 sets of interconnects and 1 set of speaker connects made a very noticeable difference.
PostPosted: Thu Jan 11, 2018 8:04 am
shawnwes wrote:
I once hardwired a Rega Planar 3 to a Rotel BQ 970 BX phono which I had a tech mount an ALPs volume pot on the front to direct drive the amp. It was in turn hardwired to an Audire Model 2 amp. The speaker cables were hardwired at the speaker end to a pair of Spica TC50i's. That was a very nice revealing system and removing 3 sets of interconnects and 1 set of speaker connects made a very noticeable difference.
Thanks for sharing your experience. And therein lies the insanity of this hobby - the first poster indicated he heard no improvement in SQ from hard wire while you are indicating a positive impact. Darn it, its never an easy answer.
