It is currently Wed Sep 19, 2018 8:48 am
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2, 3  Next
PostPosted: Tue Jan 02, 2018 7:31 pm
Another one of those cheap as borscht chinese stylus force gauges just stopped working for me. I'm pretty much done with these cheap things. Anyone know stores in the GTA that carry reliable vtf gauges that don't cost an arm and a leg?
Byrpn
Friedrich Nietzsche
PostPosted: Tue Jan 02, 2018 7:45 pm
I know the Parts Connexion folks are always advertising theirs, but I have no idea as to it's quality....
PostPosted: Tue Jan 02, 2018 7:47 pm
walmart?
https://www.walmart.ca/en/ip/Insten-300 ... MWZAR85UI9
Or you could find an ortofon dealer, call and ask if they have a cart balance. Should cost less than $25.
https://www.ortofon.com/stylus-pressure ... cale-p-279
PostPosted: Wed Jan 03, 2018 3:30 am
I use this from Amazon:
https://www.amazon.ca/Neoteck-Digital-Turntable-Backlight-Cartridge/dp/B01HRJ9NAY/
I have a Christian Becker 5g calibration weight and the scale is right on ... at 5g anyway! :D
Edits:
Trying to get the link to work. Grrrr
PostPosted: Wed Jan 03, 2018 3:52 am
Edits:
That's exactly the cheapskate ones I've been using and I am tired of them failing on me (I've had three or four!)
B
Friedrich Nietzsche
PostPosted: Wed Jan 03, 2018 4:02 am
I must have gotten lucky. No problems so far.
PostPosted: Wed Jan 03, 2018 4:10 am
The first one, I dropped. My bad, The second and third just stopped working...no reason. Not sure...I'll likely just buy another one anyway, unless I happen to get down to a dealer at some point soon...
b
Friedrich Nietzsche
PostPosted: Wed Jan 03, 2018 4:38 am
Curious, can you return the gauge if you bought it from Amazon?
PostPosted: Wed Jan 03, 2018 4:47 am
Silly question but I am going to assume you checked the battery?
I own the Pro-Ject branded gauge which is similar to the one linked from Amazon – although a lot more expensive (~$100). No problems so far
Rega just released their own if you are willing to dish out $250 US.
http://www.rega.co.uk/atlas.html
Outside of that, the Ortofon digital gauge goes for around $180
PostPosted: Wed Jan 03, 2018 4:56 am
Yeah, I replaced the batteries thinking that it might be the issue. The problem is that for anything over ~ 1g it says 'FULL'...there appears to be no factory reset or anything else...
b
Friedrich Nietzsche
PostPosted: Wed Jan 03, 2018 5:35 am
I got mine from Fleabay for $6.99 shipped and it works well. I also have the Shure as a back up. Remove the mat and place the guage directly on the platter for a more accurate reading.
PostPosted: Wed Jan 03, 2018 5:42 am
TFA demonstrated a DIY stylus gauge.
https://www.takefiveaudio.com/contents/ ... forcegauge
PostPosted: Wed Jan 03, 2018 6:44 am
The Amazon, the Parts Connexion ($50) and many others all appear to be the same as mine but from D-Ex in China for $13. (I also use an Ortofon balance scale ($10 ish) as a second opinion). I also have one in a cd box that is unreliable.
The Chi one has three buttons across the top and can be recalibrate. It may be as simple as you changed the mode. Did you keep the instructions?
I'm thinking mine's been around for 7-8 years or more..
PostPosted: Wed Jan 03, 2018 6:57 am
yeah, it's in grams for sure...but I wonder if I need to recalibrate - I might try that, though I don't think mine came with the 5g weight...will have to find one!
b
Friedrich Nietzsche
PostPosted: Wed Jan 03, 2018 7:29 am
Byrpn
You may wish to look at the Ortofon DS-3 Gauge...made in Japan
https://www.ortofon.com/ds-3-digital-st ... 708-n-3444
Regards,
MKoM, Toronto
"Music is the movement of sound to reach the soul for the education of its virtue." Plato
MKOM represents designs which combine the pinnacle of Audio Engineering Excellence with in-house experience.
Visit: http://www.mykindofmusic.com
Users browsing this forum: David P and 14 guests
