It is currently Thu Jan 18, 2018 1:22 pm
PostPosted: Thu Dec 14, 2017 7:18 am
I have 2 cassette decks ( Yamaha KX-R470 and JVC TD-V531 ) both decks have similar issues when pressing PLAY. The Yamaha will usually go to FF, The JVC will toggle the MONITOR function from SOURCE to TAPE, after 3 or 4 tries, it will start to play. Any suggestions?
PostPosted: Thu Dec 14, 2017 7:46 am
How old are these?
PostPosted: Thu Dec 14, 2017 8:15 am
Tape decks need to be serviced periodically to stay running properly.
PostPosted: Thu Dec 14, 2017 8:20 am
Both are logic(computer) controlled.
Guessing caps surrounding logic chips failing or maybe power supply feeding those chips failing.
Service required.
PostPosted: Thu Dec 14, 2017 9:50 am
Probably both from 80's. Caps may be good target, if I can find replacements, certainly worth a try. Can I assume the caps would be connected to the ICs' +5 vdc pins?
Users browsing this forum: Google [Bot], VintageJoe3 and 0 guests
