It is currently Sun Sep 23, 2018 4:57 am
PostPosted: Wed Dec 13, 2017 9:06 am
What manufactures make a USB cable that separates the power from the signal in a single wire?
Logically from a technical point of view it makes sense that you would want the power element separate from the signal element to reduce/eliminate as much interference as possible in the signal.
Brands/models that use this design?
Thanks, in advance,
Audiois1st
PostPosted: Wed Dec 13, 2017 9:12 am
Wireworld do it in USB and HDMI
Davidson Home Audio Designs
PostPosted: Wed Dec 13, 2017 9:40 am
Audio Sensibility makes them.
PostPosted: Wed Dec 13, 2017 10:12 am
Go "local" with Audio Sensibility. Plus, Steve is a really great guy. I bought his USB Statement Silver and it is an amazing cable. Switched back to Belkin one evening just to test I'm not buying into the cable hype, and it was like someone pulled a curtain over my speakers. No comparison.
PostPosted: Wed Dec 13, 2017 11:11 am
Thanks for the replies so far, so to recap their are two options Wireworld or Audio Sensibility.
The Wireworld ULTRAVIOLET 7 and the Audio Sensibility Impact SE are at least affordable options.
Any others?
Audiois1st
PostPosted: Wed Dec 13, 2017 11:35 am
Don't mean to sidetrack but , if ones Dac draws no power from PC does it matter ?
PostPosted: Wed Dec 13, 2017 11:44 am
Good question......I wonder if anything is sent down that line at all if power isn't required.....
PostPosted: Wed Dec 13, 2017 12:03 pm
www.bluejeanscable.com
PostPosted: Wed Dec 13, 2017 1:09 pm
Audio_Guy wrote:
http://www.bluejeanscable.com
I can't see where they separate the power from the data......could you provide a more accurate link?
PostPosted: Wed Dec 13, 2017 1:33 pm
Separate pairs for data and power is standard. Bluejeans cables have the very best cables and quality control with extensive testing of all of their products. Not to mention very realistic pricing - no foo here. I have never had a reason to doubt that their products meet or exceed and standards.
PostPosted: Wed Dec 13, 2017 1:37 pm
Ummmmmm...Obviously they are different wires lol. I don't think that is what the OP is looking for. I believe he is looking for a cable where they are completely physically separated from one another in a separate run entirely
Also, quality control, testing "foo" and all that jazz aren't the topic here.
PostPosted: Wed Dec 13, 2017 1:41 pm
Like this:
PostPosted: Wed Dec 13, 2017 1:52 pm
Thanks, in advance,
Audiois1st
http://www.curiouscables.com
The DATA+ and DATA- pair are spec'd as a shielded pair.
PostPosted: Wed Dec 13, 2017 2:27 pm
I use a Siltech classic anniversary USB cable, outstanding performance in my system. I believe they have the power line running along the side, separated, but still in the inner sleeve. The extremely well regarded audience au24, another outstanding performer, is designed with the separate line as well. If memory serves, the curious cable does this also, along with the cardas clear. There are a bunch of them out there.
