It is currently Sat Jun 23, 2018 2:00 am
 Post subject: Phono Cable
PostPosted: Tue Dec 12, 2017 10:56 am
I have a stock cable on my DV507 mkII tonearm. Apparently, the cable that makes the biggest difference is the phono cable.
Will the audio sensibility cable be an improvement? Which one? Do they have a home audition available?
Thanks.
 Post subject: Re: Phono Cable
PostPosted: Tue Dec 12, 2017 11:12 am
Despite that I feel a cable can have more of an impact with a low level phono signal that with a line level, I wouldn’t say it guarantees an improvement. What is pleasing to me may not be pleasing you which in turn could be different from the next guy. I have had excellent results from OCC (Ohno Continuous Casting) cable (non Audio Sensibility), more so than the dozen of others I have tried. If interested but yet skeptical, see if you can borrow one from a fellow member. Or drop Steve from Audio Sensibility a line. Awesome guy – I’m sure he will be more than happy to answer any questions and perhaps have something you can audition (I do not know this for sure, but doesn’t hurt to ask)
I am assuming the DV507 is a din connection?
PostPosted: Tue Dec 12, 2017 11:41 am
Yes, it's a DIN. AFAIK, the phono cable is made by furutech.
In my experience, wire is overpriced. Which makes me very careful. It's something that I cannot reliably detect.
It could just be about the circuits involved when subjected to small changes in capacitive/inductive loading. Which would explain very well why the same cable in two systems can sound remarkably different.
I'd like to think that my system is immune to cable changes, and I'm just not deaf, but... I'm an old goat.
PostPosted: Tue Dec 12, 2017 12:01 pm
It really depends on how good the stock phono cable is. Some are very good, and some are just an afterthought. I find stock Linn tonearm cables to be pretty average, and I replaced the ones on both my Ittock (with Cardas Neutral Reference) and Akito tonearms (with XLO Reference Series). I also think that the quality of the DIN connectors makes a big difference. Cardas and SME make very nice DIN connectors, but I avoid generic molded ones.
PostPosted: Tue Dec 12, 2017 12:04 pm
Well…the only way to know is to try. But for the record, Furutech also uses OCC drawn copper and silver. Not saying yours employs this technology, just saying they do use it.
PostPosted: Tue Dec 12, 2017 12:15 pm
What's the cartridge?
PostPosted: Tue Dec 12, 2017 1:02 pm
Koetsu Black Goldline.
PostPosted: Tue Dec 12, 2017 1:35 pm
I would say the Furutech should be decent for D507 and Koetsu, but if you want an upgrade go for Nordost( any budget you have)
PostPosted: Tue Dec 12, 2017 2:54 pm
Nice cartridge. Tell ya what…I do not have a phono cable with a DIN connection to loan you, so how about you lend me the Koetsu and I’ll report back with my findings. :wink:
Can’t comment on the Furutech. But do believe from experience that changing the cable will give you a different result. Whether that result is positive or not will all be dependent on your perception of the outcome.
PostPosted: Tue Dec 12, 2017 3:01 pm
Upgraded to a Crystal Cable 'Standard Diamond' on my air bearing MG-1 with a LYRA SKALA...vast improvement all the way around!!!
I Put A Spell On You!!!
