It is currently Fri Jan 19, 2018 9:07 pm
PostPosted: Sun Dec 10, 2017 1:15 pm
Anyone with a JL Audio E110 or E112 sub having trouble with the level (volume) cutting in and out when you turn the level control knob up or down?
PostPosted: Sun Dec 10, 2017 3:06 pm
Nope. Had my E110 for 18 months
PostPosted: Sun Dec 10, 2017 5:11 pm
might just need a good cleaning with contact cleaner. deoxit is good to use.
PostPosted: Sun Dec 10, 2017 6:29 pm
I've had two since 2015, no problems. I agree it sounds like a dirty pot which could be solved with Deoxit.
PostPosted: Sun Dec 10, 2017 9:55 pm
I had this problem. Call or email JL Canada. They sent me a new amp and driver for free, but I had to pay shipping to send the old parts back, I guess they refurb the amps. My sub eventually stopped working, and I never touched the volume. It’s a very common problem, So Hopefully JL takes care of you.
I also took the amp apart and tried cleaning the volume pot. It didn’t work.
PostPosted: Sun Dec 10, 2017 10:25 pm
I have been running mine for about 5 months with no issues.
I love it btw.
PostPosted: Sat Dec 23, 2017 3:46 pm
My E110 would all of a sudden take off to full volume and the volume wouldn't turn it back down. Had to unplug it to reset itself. Keeps happening.
I contacted JBL and they said it was the potentiometer for the volume and it would require a new amp.
I'll take it to a shop some day if I have the use for a sub again. Would be silly if I had to replace the whole amp for a a small fix like that.
-- 23 Dec 2017 17:47 --
Did you have to supply them with a receipt of purchase?
Amp: Line Magnetic 508
Pre amp: LTA MZ2
DAC: Chord 2Qute
Turntable: Rega RP1 w/ Rega Fono Mini A2D
CD Player: NAD 517
Speakers: Coming soon...Audio Note Kit 03
PostPosted: Sat Dec 23, 2017 4:57 pm
JL Canada exists ?
Pls let me their contact info
Thank you.
PostPosted: Sun Dec 24, 2017 7:06 am
JL Canada exists ?
Thank you.
http://www.jlaudio.ca/footer/Contact+Us ... on/1170497
Pre amp: LTA MZ2
DAC: Chord 2Qute
CD Player: NAD 517
PostPosted: Sun Dec 24, 2017 8:28 am
347strokin wrote:
JL Canada exists ?
Thank you.
Thank you a whole bunch.
PostPosted: Thu Jan 11, 2018 1:11 pm
Seems I spoke too soon, one of my subs now suffers from the issue described above. Since mine are sequential serial numbers, and this is apparently a problem with the batch, I'm going to send in both sub amp boards for replacement. Thanks to the OP for posting about this problem.
