It is currently Tue Sep 18, 2018 9:40 pm
 Post subject: Trends Audio amp upgrade
PostPosted: Wed Dec 06, 2017 12:18 pm
Just got news from Trends Audio that the ALPS volume pot is now standard on the base 10.2 amp.
https://www.trendsaudio.com/index.php?o ... 28&lang=en
UNITY AUDIO
PostPosted: Wed Dec 06, 2017 3:20 pm
Not knocking the little amp - I have a SMSL version (and love what it can do), but - is a volume pod upgrade even worth it (noticeable) in one of these?
Seems like overkill in a cheaply marketed amp.
PostPosted: Wed Dec 06, 2017 3:49 pm
Yes it is - the Taiwan made one that it replaces had balance issues, and it choked the sound a bit.
UNITY AUDIO
PostPosted: Wed Dec 06, 2017 5:09 pm
Interesting.
Guess I was lucky with my SMSL...
Never had a problem, perfectly balanced from left to right.
I have to comment - these little chip amps really do a good job.
I run mine as a secondary system in the family room.
Just simple a simple Tivoli Bluetooth connected to it - driving a pair of full-range fostex in a pair of side horns.
It certainly could benefit from a different source, but it's just being used for background.
Back to the point, these more simple things often make you wonder if all the fuss for bigger & "better" is worth it
PostPosted: Wed Dec 06, 2017 6:00 pm
Any ideas about the ohm spec on that ALPS volume pot? I've got a Trends amp laying around somewhere and it needs a retrofit. I bought it under the pre-text of using it at garage sales (with a DC/AC inverter) to test speakers. Never happened but a nice thought.
PostPosted: Wed Dec 06, 2017 8:19 pm
buybye88 wrote:
I've sent a message to them, waiting on a reply.
UNITY AUDIO
PostPosted: Thu Dec 07, 2017 9:40 am
buybye88 wrote:
It uses the 50kBX2
UNITY AUDIO
PostPosted: Thu Dec 07, 2017 3:55 pm
note to cableguy: many thanks for checking this out. The old Trends stock volume control is pretty flimsy and noisy to boot and I doubt it tracks evenly on both channels. But an ALPS ..... well, that is another story .....
PostPosted: Thu Dec 07, 2017 4:55 pm
buybye88 wrote:
Happy to help David!
Omer
UNITY AUDIO
