It is currently Tue Jan 16, 2018 11:34 am
PostPosted: Sun Dec 03, 2017 9:08 am
Just wondering if anyone else has had problems with the power switches. I had a power switch snap on me about two years ago. Older amps and I expect things to wear out. Ordered two new switches, one for each amp. Fast forward two years and now I have had another one snap. Anyone else have a problem, and is there a better company to get switches?
Thanks
PostPosted: Sun Dec 03, 2017 9:32 am
I have a Classe' Ten (not in use at the moment) but no issues at all with the power switch.
I rarely turn things off so it got minimal use.
PostPosted: Sun Dec 03, 2017 9:45 am
Both my dr9 had issues replaced both .now switch still works but light doesn't come on cant be bother to replace
PostPosted: Sun Dec 03, 2017 10:00 am
No issues with dr-3 or dr-3vhc power switch and have had them in the family since new
PostPosted: Sun Dec 03, 2017 10:05 am
I am really hoping this premature failure is a one off and not a reoccurring flaw.
Oh, and you think I can find that old working switch that I removed?
PostPosted: Sat Dec 09, 2017 12:17 pm
If you speak of the big black flip switches (no light)...they are fairly common. The big deal is that flipping them hard and fast does put mechanical stress on them. The switches themselves are fairly common. I'm looking at the guts of them via images and it appears to be a two pole switch, 15A 125VAC rated. Are you flipping them hard and fast, to try and cut down on potentials for arching?
Replacements are common and of good manufacture...as this type of switch is generally used to lift both line and neutral from the circuit for industrial-pro-commerical gear of various design and type. Motorized gear, for example.
PostPosted: Sat Dec 09, 2017 12:22 pm
Agree - I run three of the VHCs and the switches have always functioned perfectly. Maybe the newer models switched to an alternate design that experiences material embrittlement with age?
PostPosted: Sat Dec 09, 2017 1:03 pm
Three VHC's? Your music room is going to be nice a toasty in the winter! :D Not sure I want to see your AC bill in the summer! :(
Probably sounds great though....
PostPosted: Sat Dec 09, 2017 1:09 pm
Yeah, running in Class A they make pretty good room heaters. One system isn't too bad - one of them run in stereo, but the other pair are bridged and run a quad amped (4 monoblocs) system that gets very toasty and doesn't tend to get as much use in summer.
I forget the power draw at idle - something like 800 watts a piece - they actually put out a bit less heat when converting some of that to sound. Sure sound great though.
PostPosted: Sat Dec 09, 2017 6:42 pm
They are the DR-8 switches with the built in light. They really are a poor design. If I could find something better to replace them with I would. On the first one the metal connector inside snapped from years of use. This one has folded over so the amp is stuck on all the time. Hoping if I order another one I won't have the same problem.
As a side note, love the amps.
PostPosted: Sun Dec 10, 2017 8:09 pm
have 2 dr-8's. right now one has a light burnt out, and I have had the other one repaired years ago.
a couple years ago, the switch on one wouldn't work for about a week, then started working again on its own. I've learned to live with this because I like the sound of them, but it's a pain
PostPosted: Mon Dec 11, 2017 3:38 am
Thanks
Its a good practice to connect an AC rated cap across the "hot" (black wire)
on the switch. This helps to prevent the contacts from arcing when switched on.
Check to see if Classe has a cap connected to the power switch.
It must be a cap rated for AC use.
PostPosted: Mon Dec 11, 2017 4:33 am
A pic of the switch with MFG and part# would help.
See if we can do a cross reference.
PostPosted: Mon Dec 11, 2017 6:32 am
photos
PostPosted: Mon Dec 11, 2017 6:50 am
Carling was gonna be my first suggestion.
