It is currently Thu Feb 22, 2018 2:55 pm
PostPosted: Fri Nov 24, 2017 1:21 pm
ive got 2 subwoofers im using in my 2 channel stereo looking for ideas for interconnects that would be a Great Subwoofer Cable
PostPosted: Fri Nov 24, 2017 1:43 pm
I started with purpose built sub woofer cables; just Energy brand.
was able to use shorter ones so I replaced with a pair of straight wire that I had.
found the bass to be cleaner with the energy cables so I went back.
PostPosted: Fri Nov 24, 2017 2:14 pm
What length of cables do you need??
The Coincident CST-1 Interconnect RCA cables would work extremely well for you.
PostPosted: Fri Nov 24, 2017 2:30 pm
6ft
-- 24 Nov 2017 22:34 --
what about Zu Cables any good
PostPosted: Fri Nov 24, 2017 2:37 pm
How about TFA made to length?
https://www.takefiveaudio.com/products/ ... o-treated/
PostPosted: Fri Nov 24, 2017 4:18 pm
sthomas1049 wrote:
Seconded: I have a few of the original version and have not been tempted to upgrade.
PostPosted: Fri Nov 24, 2017 4:26 pm
Belden 8402 is the best.....
PostPosted: Fri Nov 24, 2017 8:32 pm
https://www.kimber.com/products/CADENCE
PostPosted: Sat Nov 25, 2017 4:14 am
Mogami Mogami Mogami
