It is currently Sun May 20, 2018 1:35 pm
 Post subject: Clements rt7 crossover
PostPosted: Wed Nov 22, 2017 4:44 pm
I'm trying to rebuild the crossover and I put a stop...can't find any information about the inductors ( this is the American model- in the Canadian model there are no inductors). I even emailed to Philip Clements but no response. Not many information on the net. Anybody familiar with this?
And, of course, thanks in advance!
PostPosted: Wed Nov 22, 2017 5:40 pm
While I can't help with specifics, I also can't help asking... Are you looking to replace the inductors? For any specific reason?
Dave
PostPosted: Thu Nov 23, 2017 1:26 am
Not both of them - just the air core one. It is damaged ( probably the reason I paid just few bucks for the speakers ...). And of course on top of both woofers being stuck
PostPosted: Thu Nov 23, 2017 3:40 am
Here are some pics I had from when I recapped mine.
PostPosted: Fri Nov 24, 2017 2:00 pm
Wow, looks a lot different. For sure mine is newer or someone already played with it...
PostPosted: Fri Nov 24, 2017 8:16 pm
Values on caps and resistors are the same. it just looks like they squeezed everything together to fit on the back of the rear plate. I'm not sure if all you need is the mH number to replace the air core as there's another number on there you can't really make out.
PostPosted: Mon Nov 27, 2017 11:14 am
Great. I should be able to find something similar. And usually they're cheap. Thanks for the help!
