It is currently Sat Sep 22, 2018 6:21 pm
PostPosted: Wed Nov 22, 2017 4:17 pm
Hello all,
First time poster here.
I have recently acquired a set of L100's that I am going to be restoring. I thought it would be very cool to put original grills back on them if I could find them at a reasonable price. Saw them on **bay but not ready to drop $450.00 on a set.
They look to me like a CNC machine could produce them for me if I knew the type of foam that was suitable. Anyone else tried this?
Idea's and suggestion are most welcome.
PK
PostPosted: Wed Nov 22, 2017 4:19 pm
might not need a cnc machine. A jig and a dremel might work just as well.
You will need a very sharp blade.....or... compress the foam, cover it with a sheet when it is compressed and do the cut through the sheet, on the compressed foam. Or some variation thereof.
Like a set of boards with a slit space between them..you clamp the foam down... and you cut a strip down in the gap With a razor or the dremel, where the compressed foam is. A 45 degree cut on compressed foam will be 60 degrees or more when the foam is uncompressed. That kinda thing.
Foam is cheap, regarding experimentation.
Might take a few tries to get it right, but it might be doable for cheap.
PostPosted: Wed Nov 22, 2017 4:44 pm
Done with a hot wire at the factory.I think an article at lansingheritage tells why this was done.
PostPosted: Wed Nov 22, 2017 5:27 pm
Try here. I would think you would have to very committed with many tries to get it right on your own.
http://www.foamspeakergrilles.com/home
good luck
PostPosted: Wed Nov 22, 2017 5:32 pm
Thanks for the replies. Now that I think about it I think even a CNC machine wood pole the foam and not get perfect cuts using a saw blade I think would produce Les than Factory results as well. The hot wire makes perfect sense. does anybody know what type of foam or where to get the foam from.
