It is currently Mon Jul 16, 2018 7:38 pm
PostPosted: Mon Nov 20, 2017 2:23 pm
I just acquired these mission 770 locally with matching stands. They worked fine with the AA battery test at sellers. So I bought them. I opened them up for a recap job when I got home and found that somebody altered the crossover. A cap was disconnected parts were added. Here's some pics can anyone help me get these close to factory wiring.
PostPosted: Mon Nov 20, 2017 3:03 pm
seems he only difference is that 2.1 uf capacitors was disconnected. if that is the case , you have to ask yourself why. it might be shorted or bad thus why previous owner unplugged it. if it is ok then just reweld it. right now they use both capacitor in parralel so they add up to 10 uf + 2.1 uf = 12.1 uf so now it is only 10 uf because the 2.1 uf disconnected according to the 2 diagram you show, resistance are identicle, what are the change you say where done?
PostPosted: Mon Nov 20, 2017 3:26 pm
The new white glue is where the non-oem parts are stuck. Both caps that were disconnected tested good. It's looks like an inductor was added with a few resistors.
Here my guess to the factory wiring job. Unsure of high pass wiring
PostPosted: Mon Nov 20, 2017 3:56 pm
did both xover have those extra coils added.the coils is there for tweeter to make it a 12/d/b oct. second order if there was none on original xover, then they where maybe only 6 d/b oct. are all driver original. if driver where change, xover change might have been done to accommodate new drivers. or simply xover modified to improve overall sound.
but judging by the xover layout. seems there was already 3 coils in circuit. maybe coil came loose with vibration. and owner try to patch it up , without noticing capacitor disconnected??? I would start by just weld capacitor in place. and listen how it sound.
the best would be to get a schematic and check back both xover for modification.
PostPosted: Mon Nov 20, 2017 5:06 pm
Drivers are original. The cap was purposely taken out of circuit as you can see it was cut. This is a 770s crossover from the internet from diyaudio. Some differences for sure.
PostPosted: Mon Nov 20, 2017 5:38 pm
Hope you get them squared away. They are fantastic speakers, even by today's standards. I had a pair many years ago.
Was the seller the original owner? If so then a pox on him for selling the speakers in that condition without full disclosure. Why do I have a feeling it was a Kijiji sale?
PostPosted: Mon Nov 20, 2017 6:20 pm
you want them like the original then you will need to keep the 2 original coils, and get the right capacitor value, and might as well buy new capacitor to replace the old ones, I would also change resistance to mill specs, much better sound and 2% values insteed of 10% maybe $40 worth of parts. at less it was not a complicated xover, as long as you know the uf values.
PostPosted: Mon Nov 20, 2017 7:03 pm
It was from one those facebook buy and sell groups. Original owner without a doubt the ad with his fb profile matches the original bill of sale. (Removed his name from bill of sale). These were expensive speakers for 1986. All I did was a AA battery test upon purchase for $90 confirming drivers passed current. Also they came with the sometimes missing stands.
The situation is frustrating but not much i can do about it.
PostPosted: Tue Nov 21, 2017 11:32 am
$90.00 with stands? Oh you absolutely stole 'em. Once you get the crossover issues sorted out you will be a happy man. Hopefully it won't cost much to bring them back to spec.
PostPosted: Tue Nov 21, 2017 6:57 pm
AFIK, those drivers are not stock originals. They never appeared together in a 770 box.
took a deeper interwebs look.
I stand corrected.
it's the 'S' part that fooled me. 770.....S.
so...audax sourced tweeter (?) and possibly an ELAC sourced custom woofer, by the looks of it.
PostPosted: Tue Nov 21, 2017 7:23 pm
Here's a pair of 770s' from the early '80s, the 1st version I believe. Tweeters were SEAS ferrofluid.
615751-original_mission_770_loudspeakers_british_classics.jpg [ 311.41 KiB | Viewed 508 times ]
PostPosted: Wed Nov 22, 2017 1:51 am
Plz note the picture order ain't right
Ok thanks to audio karma I can confirm this is the factory crossover.
Then from diy audio which is another confirmation
Which basically double confirms it.
Then I discovered this cut below the inductor wire. A wire that should be connected according to those pictures. Which triple backs up that those pictures is how it's supposed to be wired.
I just need to the the values of the resistors and I'm sure I can salvage it.
-- 22 Nov 2017 09:55 --
This is how mine looks. I started disconnecting wires.
Users browsing this forum: davelr and 3 guests
