It is currently Fri Jul 20, 2018 2:48 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 20 posts ]  Go to page 1, 2  Next
 Post subject: 2 cable difference
PostPosted: Sun Nov 19, 2017 11:13 am
i
 Post subject: Re: 2 cable difference
PostPosted: Sun Nov 19, 2017 11:25 am
@seb7772, you are surprised to hear so little difference between the sound of the two cables, when the difference between their prices is so big ?
You must be new to this hobby. Welcome to CAM !
It's not really possible to comment meaningfully. Associated gear, connections, listening conditions, type of music are some of the variables you don't mention.
And apart from that, just about everyone at CAM is aware of what is commonly called the Law of Diminishing Returns, which says that the amount of improvement you get for a dollar diminishes the more you spend.
Now the "law" is a little disingenuous, because when a system provides a lot of musical information, a very little bit more information may give a large increase in musical pleasure. But most CAMmers are also aware that some equipment is built for and sold to people with more money than audio knowledge.
PostPosted: Sun Nov 19, 2017 11:34 am
if you go by 25% of system value is cabling well at 9k wires on lets say u run the venere s at 7k , as Savage used to say, "well there's yer problem".
the rest of the system could be the weak link.
PostPosted: Sun Nov 19, 2017 11:56 am
Personally I wouldn't be using SF Venere paired with NAD Masters as a benchmark for testing differences in gear. Everything from sources to cables I tried introducing to my M22/M12 setup sounded almost the same. That is a good or a bad thing depending on how you look at it.
$$$ doesn't always equal performance increase with cables but why even consider $9500 speaker cables with a system like that? 12TC are perfectly fine.
PostPosted: Sun Nov 19, 2017 12:05 pm
Delivered with a bit of unhappiness, the line goes "10x the price for 10% of an improvement".
It's the same (Soft) rule in almost all areas of human endeavor.
As the markets and people are built this way, they (people) can have a hard time recognizing when something truly different comes along. Something that breaks those rules.
The systems are usually so established that it takes a near full on forced explosion in the given stable market, to break up the given status quo. then, so many people are invested in the given status quo, that most are unaware and the rest actively fight to keep the status quo as it is. Even if they don't really like it. Apathy, ignorance, and desire tend to keep given markets from forms of change.
I have come up against this all the time, across multiple fields of technology and endeavor. The kind of things, or scenarios..... that most don't even recognize as existing.
Real change, as they say, leaves no prior extant top dogs intact. It sweeps everyone away. Hence their fight.
PostPosted: Sun Nov 19, 2017 12:56 pm
PostPosted: Sun Nov 19, 2017 12:57 pm
b3733366 wrote:
My comment ... Be happy! ... would have been a bit of a bummer the other way. ;)
Word
Davidson Home Audio Designs
PostPosted: Sun Nov 19, 2017 1:43 pm
So “real change” justifies the extremely high prices your company charges for the cables you promote on this site? Don’t your speaker cables go for more than $10k a pair?
PostPosted: Sun Nov 19, 2017 1:51 pm
I believe you will find that most cable manufacturers build a 'line' of cable products that sound similar to each other. The reason for this is the powers that be prefer that particular 'sonic signature'.
The fact that these were sold 'used' at a drastically reduced price should give you a clue as to their actual worth which is very subjective at best. One man's treasure is another's trash. I also suspect that there may be a much larger sonic difference that you suspect that would be more readily revealed with better loudspeakers.
Try to be contented with whatever works well regardless of price.
J.
PostPosted: Sun Nov 19, 2017 2:35 pm
I've noticed differences in speaker cables and unbalanced interconnects. Not so much for power cables. I think my power is relatively clean coming into the house.
But, I keep it fairly reasonable and use fairly pedestrian grade Kimbers 4PR and Ultalink Ambiance cables. I've found both to sound reasonably good.
If I had a 50K system, I'd probably spend more on cables...
PostPosted: Sun Nov 19, 2017 2:39 pm
Why has the OP edited his post removing the original question? :roll:
PostPosted: Sun Nov 19, 2017 2:42 pm
...not cool...shouldn't be allowed...
PostPosted: Sun Nov 19, 2017 3:08 pm
Zut alors! Posters remorse!
PostPosted: Sun Nov 19, 2017 3:35 pm
We should put ELOS on that case.... :idea:
PostPosted: Sun Nov 19, 2017 3:48 pm
:lol:
