It is currently Mon Jul 16, 2018 7:47 pm
 Post subject: DAC and amp noise
PostPosted: Sat Nov 18, 2017 12:17 pm
PS Audio Stellar DAC and Sonneteer integrated amp. Both plug into the same outlet (one plug at top and one plug at bottom of outlet).
When I crank up volume on amp with no source there is a very loud hum. If I unplug the DAC there is zero noise.
I believe (???) this might be a groundloop? Or is it something else.
And how do I get rid of it?
Much thanks!
 Post subject: Re: DAC and amp noise
PostPosted: Sat Nov 18, 2017 12:30 pm
I'm sure you already have it setup like this but just to confirm the obvious. Is the Stellar DAC volume set to 76? At 100 it has a +12dB output, not sure if that would create an undesirable effect with the integrated.
"With the volume set to 76 the Stellar Gain Cell DAC is a line level device. With the volume set 100 the Stellar Gain Cell DAC produces an output of +12dB. Bear this in mind when turning up the volume."
PostPosted: Sat Nov 18, 2017 1:26 pm
I have the Stellar set at 25 ... I'm using the Sonneteer for volume control rather than the DAC ... if the amp volume is set too low it's not going to produce good sound ... so I've started with low volume on the DAC and slightly higher volume on the amp.
PostPosted: Sat Nov 18, 2017 1:37 pm
It's my understanding that the Stellar should be set to 76 volume when being used as a standalone DAC. I've emailed PS Audio to confirm. Your issue is more than likely not DAC related but you never know. I've had what you describe occur with some amps in the past and like you stated in the post it was a ground loop issue.
PostPosted: Sat Nov 18, 2017 1:42 pm
If you are amplifing a tiny signal it gives any available noise a chance to be heard ( this is why LOMC's require a quality pre amp ).
Your're probably way ahead to set the DAC at the recommended 76 than to use 25 which is a very small signal.
Oh, and by the way. Try plugging the DAC into an outlet that's on a different breaker.
PostPosted: Sat Nov 18, 2017 2:34 pm
I’m not familiar with your DAC but I have an Alabaster and it is silent. Which line input are you using? IIRC, the direct inputs have a different gain than the other 2. I’d try the DAC set as James suggests and then try a different input if the issue persists. Good luck!
PostPosted: Sat Nov 18, 2017 2:56 pm
Are you using fancy esoteric type interconnects?
PostPosted: Sat Nov 18, 2017 4:26 pm
Thanks James,
Will try both suggestions!
Users browsing this forum: mjlindsay and 10 guests
