It is currently Mon Jul 16, 2018 7:41 pm
PostPosted: Fri Nov 17, 2017 8:54 am
I have a legacy preprocessor bryston sp1.7 and like to know how to feed it 5.1 digital audio (PCM or Dolby Digital only as no other formats supported) via coax or spdif. Source is netflix that is DD+ so is there a device that can convert DD+ to DD? Device needs to accept HDMI as input and output 5.1 digital audio via coax or spdif. It should also output hdmi for video in my case.
Thanx,tom.
PostPosted: Fri Nov 17, 2017 10:35 am
Thanx,tom.
This might do the trick: Blackbird 4K Series 7.1 HDMI Audio Extractor
https://www.123inkcartridges.ca/p-35309 ... -extractor
https://www.monoprice.com/product?p_id=13348
https://www.newegg.ca/Product/Product.a ... 9HT43P6440
Just a guess though ...
Having been in this boat though ... I eventually just got a newer mid market HDMI receiver that had pre-outs ... was cheaper and easier than buying a new pre-pro.
Good luck. :)
PostPosted: Sat Nov 18, 2017 6:28 pm
You simply need a dolby 2-channel source or pcm stereo source to your Bryston SP 1.7. Using the digital mode on the SP will convert the source signal to the soundfield you choose to use, in your case Dolby 5.1 but you can also use Neo (dts), multi-channel stereo, etc..
I have Netflix from computer out to an outboard dac, dac to SP2 for 4 channel stereo. I also have Netflix on Smart TV but just use the speakers on the TV.
