It is currently Fri Jul 20, 2018 4:49 am
PostPosted: Fri Nov 17, 2017 6:37 am
So right now I have a clearaudio concept on it. White cleaning the needle got bent and snapped off by the one who cleans the house.
I would like to replace the cart with maybe something better. The only requirement is that the cart has to be MM and under $500.
What do you guys suggest? Speaking with few people / dealers I was recommended Goldring 2400 as a very good upgrade and good match for the tonearm.
What say you?
PostPosted: Fri Nov 17, 2017 7:33 am
Yes, that's a good match. Also Dynavector 10x5 or Nagaoka MP200. That arm is quite ringy, so avoid anything too thin and bright.
Planet of Sound
PostPosted: Fri Nov 17, 2017 8:14 am
If you are thinking 2400, it is worth the little bit more for the 2500 in my opinion.
Davidson Home Audio Designs
PostPosted: Fri Nov 17, 2017 9:35 am
also better learn how to clean the house .
PostPosted: Fri Nov 17, 2017 10:16 am
I replaced the cart on my friend's Marantz about two months ago. Went with a Denon DL-110 and it is a hit. Smooth, responsive and great sound stage. I prefer it to my 10X5 on my P6 to be honest. The 110 is a good fit with your deck.
PostPosted: Fri Nov 17, 2017 10:55 am
I have own 4 stock concept tables and found that the Nagaoka MP 150 or 200 works very well with this table
PostPosted: Fri Nov 17, 2017 3:08 pm
I think it's a house cleaning issue as well
PostPosted: Fri Nov 17, 2017 3:40 pm
Yes. A restraining order is necessary. The aforementioned 'cleaner' must not enter a 10-foot No Entry Zone surrounding the tt.
PostPosted: Fri Nov 17, 2017 3:58 pm
Oh, by the way, my friend bought a proper cover for his deck. Cleaning lady problem solved. :lol:
