It is currently Mon Jan 22, 2018 4:15 am
 Post subject: Turntable Belts
PostPosted: Sun Oct 22, 2017 9:30 am
I have just finished a turntable project and wanting to source out a longer 2mm belt. I have been using a Clearaudio 36 in silicone belt from my Emotion table and while it works I believe there is too much tension. The platter turns very freely when the belt is not attached but when attached it is tight with no inertia. The motor is a stand alone 10 watt AC VPI motor so lots of power so not concerned about the strength and the Delrin platter weighs about8 pounds. I have heard thar you can use fishing line but not sure if the knot will bother me. I am thinking of a 38 inch might be better. I have attached a photo. Thanks
 Post subject: Re: Turntable Belts
PostPosted: Sun Oct 22, 2017 9:53 am
I found silk thread to be more to my liking than fishing line, more flex in the material and the knot sounds quieter. Saying that I bought an Origin Live belt and it works great, has enough flex and is super quiet. They will make any length you want, nice table by the way.
PostPosted: Sun Oct 22, 2017 10:23 am
If you decide you want to go rubber, then there may be something here:
http://www.a1parts.com/belts/prb_rubber_belts.htm
also, try the main prb website
