It is currently Sat Aug 18, 2018 2:15 pm
PostPosted: Fri Oct 20, 2017 8:29 am
Hey all, i searched and found some info that was old so thought i'd just create a new post.
Just yesterday i found a Marantz 2015 for a good price and took that baby home. Cleaned it, lubed it, deoxited it, lights work....so far so good.
But what i did notice is the speaker terminals are the spring type....and the hole is very small. Maybe enough for 16-18 gauge wire, maybe 14 if i really squeeze to make sh!t fit (a la biggie), but certainly too small for my current 12gauge speaker wire.
From what i read online so far i can:
1) get 16-18 gauge wire
2) try to trim the 12 gauge and then tin the end (solder). Crimp it some and it might fit (however i have my reservations that this will work on this particular marantz)
3) get a certain speaker connector that accommodates 12gauge.....or flex connectors that appear to do the trick
https://www.parts-express.com/speaker-p ... --091-1255
I'd lean towards trying these but would love to find them in Canada for a reasonable price, or something comparable
https://www.amazon.ca/SilverbackSL-Gold-Connectors-Spring-Loaded-Inputs/dp/B00B1V0CRI?tag=canuckca-20" target="_blank">https://www.amazon.ca/SilverbackSL-Gold ... B00B1V0CRI
Anyway, any suggestions or stores (or online) that i should check out that might carry the flex connectors would be appreciated
thanks!
(Kitchener, Ontario)
https://www.facebook.com/APlaceToBuyTurntableNeedles/
PostPosted: Fri Oct 20, 2017 8:50 am
The weak link is the spring terminals so why not address those if it's such a concern?
On the other hand considering those same terminals were good enough for the last X number of decades as was the gauge of wire why the sudden need to change?
PostPosted: Fri Oct 20, 2017 9:13 am
i'm not opposed to getting thinner speaker wire really. but since i already have my 12ga currently run i'd love to be able to just use it if i can.....
PostPosted: Fri Oct 20, 2017 9:30 am
Then replace spring terminals with some nice 5 ways?
PostPosted: Fri Oct 20, 2017 9:41 am
Connect larger speaker wires to the inside of the speaker connectors
Solder?
PostPosted: Fri Oct 20, 2017 10:12 am
i don't really wanna solder when other options are likely easier....
i might just go get thinner speaker wire, and then if i keep this one i'll come up with a more long term solution.
those flex connectors do look neat
PostPosted: Fri Oct 20, 2017 11:30 am
Pin connectors would work.
If you don't mind the wait for Ebay purchases from China, this might be ok:
http://www.ebay.ca/itm/10pcs-Nakamichi-Hard-Plastic-Gold-2mm-Pin-Tip-Banana-Plug-Terminal-Connector/391866758834?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D20170831090034%26meid%3D8f8af865cf184c60a5248734ab16c53a%26pid%3D100005%26rk%3D6%26rkt%3D6%26sd%3D221669206748&_trksid=p2047675.c100005.m1851
PostPosted: Fri Oct 20, 2017 11:37 am
There seem to be a fair number of pin-type connectors on amazon.ca, like these:
https://www.amazon.ca/RCA-AH11N-Speaker-Wire-Mini-Pins/dp/B003GSLEJO/ref=pd_sim_23_4/146-2348213-8972100?tag=canuckca-20" target="_blank">https://www.amazon.ca/RCA-AH11N-Speaker ... 4F9P8NECDN
There are also probably tons of Canadian sources for monoprice pins.
I had the same issue with my old Marantz amp, and pins seemed easier than modding the amp or
replacing in-wall speaker wire. You could argue that ideally, they should be pure copper and as
large as the spring connectors can possibly take - but in my case I had to ask how much better $100
pins would make my old Marantz sound. For that matter, take a look at the gauge of wire connecting
those spring terminals on the inside.
Take on that world, going to go through the night.
You don't have to take on the world, you said, just get on its good side.
- Gord Downie
PostPosted: Sat Oct 21, 2017 10:04 am
THanks for the links and replies!
Users browsing this forum: David M and 5 guests
