It is currently Sat Aug 18, 2018 2:16 pm
 Post subject: speed control for tt
PostPosted: Thu Oct 19, 2017 2:54 pm
I had posted in analogue, but I think the cool cats of the DIY lounge may actually provide some in sight.
These devices seem to be very brand centric, they may not work with another tt from another company. Is there such a thing as a generic speed controller? Is it possible to build (or get a person that can) your own?
 Post subject: Re: speed control for tt
PostPosted: Thu Oct 19, 2017 4:05 pm
The Music Hall Cruise Control 2 can be used with any turntable with a 120 volt A/C motor, that does not draw more than 3 watts, unless that turntable has a regenerative power supply built in.
Alec
PostPosted: Thu Oct 19, 2017 4:08 pm
AC or DC motor?
PostPosted: Thu Oct 19, 2017 4:11 pm
Alec
Hi Alec.
I have a Rega Planar 3. Will the Music Hall work with that?
It is 120v ac and the original suspended motor.
PostPosted: Thu Oct 19, 2017 4:33 pm
Try Origin Live
PostPosted: Thu Oct 19, 2017 5:05 pm
Mod
I checked out origins live, there was nothing in the conditioners section.
was there something in particular you noticed?
PostPosted: Thu Oct 19, 2017 5:39 pm
https://www.originlive.com/dc-motor-kit.html
phoenix engineering has a speed controller at hifiheaven.net
PostPosted: Fri Oct 20, 2017 2:55 am
I didn't dig deep enough. Thanks.
PostPosted: Fri Oct 20, 2017 3:48 am
Do you have a specific table in mind?
Motor controllers are matched to the type of motor i.e. DC or AC synchronous and the motor's power requirements.
PostPosted: Fri Oct 20, 2017 6:10 am
Chipmunk1957 wrote:
Alec
Hi Alec.
I'm using mine with a Rega Planar 2 (1982), GrooveTracer subplatter, Sumiko/Jelco Premier MMT arm.
Alec
PostPosted: Fri Oct 20, 2017 8:24 am
Hey Vpi SDS is the best speed controller I've found for use with AC motors. The music Hall is not big enough for some of the motors but you are fine with the Vpi with all motors
PostPosted: Sat Oct 21, 2017 12:30 pm
It is a VPI, I just can't get past the price.
-- 21 Oct 2017 20:36 --
I checked out the music hall, it's definately affordable.
I haven't actually seen one, but it looks as though the the unit only takes a two prong plug. The power cord off the motor on my VPI has a ground pin.
PostPosted: Sat Oct 21, 2017 2:56 pm
Traveller?
The VPI is a good deck. Why do you feel you need a speed controller?
PostPosted: Sun Oct 22, 2017 3:13 am
ripblade wrote:
Traveller?
It's the scout II, and I do love it.
I did some readings with the rpm app and also used a strobe mat. It would seem it's not running to speed and it may be inconsistent speed wise as well.
So it falls into the compulsion/reaction category. Now that I know somethings not quite right, I would like to have the tt running at perfect speed.
PostPosted: Sun Oct 22, 2017 3:33 am
scarbpaul12 wrote:
ripblade wrote:
Traveller?
The Scout 2 has a stepped pulley, therefore, moving the drive belt to a different pulley groove allows for fine speed adjustments. Try playing with belt tension to allow a more linear transfer of power which will result in better speed consistency.
