It is currently Sun Feb 25, 2018 5:37 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
 Post subject: Which Tonearm Lift
PostPosted: Wed Oct 18, 2017 6:20 am
Would like some real world recommendations for an auto tone arm lift. I see prices ranging from 55 dollars and up over 400 dollars.
Mine will be going on a Lenco L70 fitted with an AT 1005 tonearm. I am not quite leaning towards the Q Up as it is rather bulky looking but the price is attractive.
Who is happy with they have tried, and are their any lifts that were a real disappointment in use ?
 Post subject: Re: Which Tonearm Lift
PostPosted: Wed Oct 18, 2017 7:53 am
I put a Q Up on my buddy's Project RPM and he is happy with it and is a few months now . It does seem rather flimsy though . There is that Canadian made one that sells for about $300, I think, that is very sweet looking , but you could get 6 of the Q Up for that price . that is the limit of my knowledge on lifts .
PostPosted: Wed Oct 18, 2017 11:44 am
Q Up looks like a plastic mousetrap. And I have heard comments on the net of folks who could not use them....perhaps the height? Not sure, but after reading about them and looking at it, I gave the "mousetrap" a pass. Currently getting off my chair before my stylus bifurcates the vinyl.....
PostPosted: Wed Oct 18, 2017 12:12 pm
The Q Up may seem flimsy but it is excellent in its execution. Easy to install (and remove if necessary) and easily adjustable. I have it on my McIntosh mt-5 and love it. In Canada its $100 but $49 US from Amazon.com (no duty, and free shipping. Better yet, get a friend to buy one- a 2 pack is $35/each!
PostPosted: Wed Oct 18, 2017 12:54 pm
There ya go !
I had the impression they might just be junk so it's great to hear from a user. I see a template you can print out of paper to check if they will fit before you buy.
I hope my Lenco will be a nice unit when it's finished but it is hard to get around the idea of dropping a couple of hundred dollars on it to lift the arm. Maybe if I go with a moving coil it would make sense.
PostPosted: Wed Oct 18, 2017 12:56 pm
If you send me your private email I will take a video to show it working
PostPosted: Wed Oct 18, 2017 6:40 pm
Thanks Mike, I have seen a bunch of you tube videos of it in action. If it looks like the Q up will fit my setup I will give one a try.
PostPosted: Sun Oct 22, 2017 6:50 am
I went and ordered one of these http://www.expressimoaudio.com/lift.html
Hopefully it will work well and look good on the table !
PostPosted: Sun Oct 22, 2017 10:48 am
I bought a Tru-lift and am very pleased with the workmanship, how it works and also how it looks.
http://www.integrityhifi.ca/tru-lift
edit: Sorry, I see that you already ordered one. Hope it works well for you! Cheers.
PostPosted: Sun Oct 22, 2017 1:17 pm
I did the same and also am quite happy.
If the other doesn't work out I recommend Tru-lift
PostPosted: Sun Oct 22, 2017 2:18 pm
I have the tru lift and find it very frustrating . The setting for the lift to work has a very narrow window turning the alen key. Once set I find it works a couple of times, then it doesn't. I then have to give the upright trip lever a light touch back and then forward. Then it will work again. It's never worked consistently since day one .
I have tried different settings to no avail. Do you guys with the tru lift have to constantly adjust the top Allen key for the release of the lift?
PostPosted: Sun Oct 22, 2017 2:25 pm
Hey Moon, I adjusted mine once after the initial setup and it worked fine since.
PostPosted: Sun Oct 22, 2017 6:05 pm
I am using a Q-Up I find it works as advertised, while it's not the most pleasing to the eye it does work..
A very adjustable unit, using it on my Pro-Ject Extension 10 without issue, but will not fit on my SL-1200MK2 as not enough space between the platter and tonearm base..
PostPosted: Mon Oct 23, 2017 2:48 am
I own a Marantz TT-15 table (made by Clearaudio). It is made of white acrylic. I suspect those tonearm lifters that use adhesive won't work....anyone with experience on what I could use?
PostPosted: Mon Oct 23, 2017 3:42 am
I’ve attached mine simply by using some Blu-Tak (actually 3M poster- same thing and easier to find).
