It is currently Fri Jul 20, 2018 4:09 pm
PostPosted: Thu Oct 05, 2017 9:39 pm
Tapping in to the vast CAM collective once again if I may. I have acquired a nice NOS Jelco LAD370D from an esteemed member, and will be mounting it on my modded TD-160 mkll. I have the beautiful cherry wood plinth installed, now the arm upgrade is next (the LVX is quite good on the table, but I believe an improvement will be realized with the oil damped 370). I've always been a Jelco fan, having had both the SA-250 and an SA-750 over the years, both very nice tonearms. In any event, I need an arm board. The LAD370D is a Jelco 9" S shaped arm that shares the same geometry as the 250 and 750, however the base has a different bolt pattern (it's not the same as the SA-370H - the H is a 9.4" arm).
I've put a Wanted ad on CAM last night for the above (long shot I know), but can you advise on who could produce this arm board locally (as in Canada)? I've tried Soundsupports overseas a few times, but can't get a response. I've also inquired with Vinyl Nirvana earlier today, and hopefully will hear back tomorrow. But, it would be nice to work with someone in Canada if possible. Many Thanks.
PostPosted: Thu Oct 05, 2017 11:39 pm
Hi Chris,
Here you go:
http://www.ebay.ca/itm/LAD-older-Jelco-Armboard-Plate-THORENS-for-TD-145-146-147-160-165-166-turntables-/152654455636?hash=item238aea2354:g:TIkAAOSwQiRUpRF2
and
http://www.ebay.ca/itm/Jelco-SA-750D-SA-250-Armboard-plate-THORENS-TD-145-146-147-160-165-166-turntable-/162636016218?hash=item25dddcaa5a:g:JjgAAOxyyq5TLo~9
Looks like Vinyl Nirvana gets their armboards from Soundsupports.
Good Luck and Happy Listening
John
PostPosted: Fri Oct 06, 2017 8:53 am
Thanks John, good lead. I'll try Soundsupports again too.
