It is currently Sat Jun 23, 2018 3:01 pm
Post new topic Reply to topic  [ 2 posts ]
PostPosted: Sat Sep 23, 2017 6:55 am
looking for some advice for a sealed encloser. i have a jl audio 10 w7 ae and two css 10 passive radiators sitting around . wondering if the passive radiators will run into problems with excursion with this sub ? also input on size of box also would be greatly appreciated .
PostPosted: Sat Sep 23, 2017 12:02 pm
Don't really have the specifics you need but when designing an enclosure to Thiele/Small parameters, using passive radiators will act much more like a ported box than the sealed enclosure type you mentioned. You will need the Vmax parameters for both the active speaker as well as the radiators and then you must determine the box tuning which is usually related to the driver's resonant frequency. Once you know some of these variables, there are various sites and calculators online to assist you with box dimensions requirements.
