It is currently Tue Apr 24, 2018 4:46 pm
Post new topic Reply to topic  [ 57 posts ]  Go to page 1, 2, 3, 4  Next
PostPosted: Fri Sep 22, 2017 8:07 pm
Looking for a matching amp with my Magnepan.
My choice would be either Bryston or Pass Labs. If I decide to go with Bryston then would be 4B3 or 7B3. If it's a Pass Labs then I'm more interested in X260.8.
Any thought ?
PostPosted: Fri Sep 22, 2017 8:18 pm
Those are very good amps but which Maggies do you own?
PostPosted: Fri Sep 22, 2017 8:20 pm
I owned the 3.7i. Thanks
PostPosted: Fri Sep 22, 2017 8:32 pm
Im a bit of a Bryston fanboy so both of those would sound great.
What are your sources.
Analog/Digital?
Turntable? Streaming?
PostPosted: Fri Sep 22, 2017 8:44 pm
Any thought ?
I have had both the 3.5 and 3.6 Maggie’s and I would highly recommend a Bryston 14B ST or SST. A 4B will not completely reveal what these beautiful speakers can do. That said, it depends partially on what kind of music you listen to. However, a big Bryston just seems to control them at any SPL.
Good luck!
PostPosted: Fri Sep 22, 2017 11:40 pm
Bryston 14Bsst2 driving a pair of Magneplanar 3.7
Power with nice Bass, effortless dynamics, soundstaging, and open highs... 8)
Steve
PostPosted: Sat Sep 23, 2017 4:18 am
A Sanders Magtech is a great match with maggies.
PostPosted: Sat Sep 23, 2017 4:39 am
I can highly recommend Spectron amps. Getting hard to find though.
PostPosted: Sat Sep 23, 2017 5:10 am
Analog/Digital?
Digital/Streaming : 60% Turntable : 40%
-- 23 Sep 2017 13:11 --
Steve
I heard the 14B is just two 7B inside of one box. Is there any sonic difference between them? I had the 28B3 and I found they sound too warm for my liking.
-- 23 Sep 2017 13:13 --
I read some reviews and they were all positive however it's so hard for me to buy something I never heard in person......
PostPosted: Sat Sep 23, 2017 5:39 am
Classe ca300 on my maggie
Any thought ?
Like to suggest if you do Bryston or Pass pls consider mono amps and perhaps a tube pre.
As someone else suggested, Spectron is the ultimate. I know because I have driven planars with all these amps.
PostPosted: Sat Sep 23, 2017 6:24 am
Same here on my 1.6QR.
PostPosted: Sat Sep 23, 2017 6:35 am
I use a Bryston 4Bsst2 for my .7's
PostPosted: Sat Sep 23, 2017 7:23 am
I use a pair of Moon W-10s on my 3.7is and have no complaints whatsoever.
PostPosted: Sat Sep 23, 2017 7:30 am
Thanks which .7 is ?
Users browsing this forum: Naimophile and 9 guests
