It is currently Tue Jan 16, 2018 1:12 am
 Post subject: Android music player
PostPosted: Tue Sep 12, 2017 4:52 pm
Hi Folks.
I have a Samsung S2 tablet which I quite like.
Loaded up a 128 gb sd card with flac and some other files.
It sounds very good thru my A/Quest Dragonfly2 dac and my phones.
Full volume is not near loud enough and so far it doesn't play ape files, and maybe others, which I seem to have a few of.
It played some flac hires files from Prostudiomasters very well.
So... what's a good player for this tablet
 Post subject: Re: Android music player
PostPosted: Tue Sep 12, 2017 5:02 pm
If using an external DAC with an Android device, you should try USB Audio Player Pro app. Android limits it digital out to 24bit 48kHz max. The USB Audio Player Pro app installs it own proprietary USB driver upon loading allowing up to 32-bit at 384kHz with a sh!t load of gain. It is worth the $10 asking price. TBH – this is the only way to go with an external DAC and a Android Smartphone/Tablet
They do offer a demo on their website so obviously try before you buy.
http://www.extreamsd.com/index.php/prod ... player-pro
https://play.google.com/store/apps/deta ... rpro&hl=en
PostPosted: Tue Sep 12, 2017 5:33 pm
You sir, have nailed it....
Thanx kindly
PostPosted: Tue Sep 12, 2017 5:53 pm
Your Welcome!
:D
PostPosted: Tue Sep 12, 2017 6:18 pm
Thanx kindly
Glad to be of help.
I’ve been using this app for a few years now. Some may think it’s interface is not as polished as other music apps, but it definitely makes up for that sound wise. The developer(s) are also on the ball constantly improving and adding new features.
Just to note, because this overrides the Android USB Audio Class, your hardware volume rocker may not work with the app…this is entirely hardware dependent. But there is an in app volume control. It’s just a bit of PIA if your device is locked.
Enjoy!
PostPosted: Tue Sep 12, 2017 7:34 pm
Well I'm quite annoyed by this whole thread. I had never thought twice about my tablet for music. I download Power amp onto my Samsung Galaxy A tablet so I could play FLAC files on it in a pinch when I'm on the road. I never gave music on the tablet a second thought after that.
Now it seems I need to think the whole thing through again. Geez, more to do, thanks a lot guys!!! :D
PostPosted: Wed Sep 13, 2017 3:12 am
Thanx kindly
Glad to be of help.
Enjoy!
I like it and sq is very good with the dac.
The gui is a little flakely when trying to return to the previous screens but no big deal.
I need to use the hardware volume control in the drop down menu to adjustit though, again no big deal.
PostPosted: Wed Sep 13, 2017 6:24 am
Not a big deal. Slap in a microSD card loaded with music and you are on your way. If playing through the HP out of the tablet, the USB Audio Player Pro app is probably not the best of choices. It will not improve on devices internal DAC like it does with the Android’s USB Audio stream. Android will still down sample to 24bit 48kHz max (assuming you are trying to play anything higher than 16bit x44.1kHz). The Power Amp app is sufficient if using the headphone out
However, you can easily add an external DAC which is where USB Audio Player shines. Just keep in mind that you need an OTG USB cable which converts the Android device to act as a host. They are not expensive but are different than your regular USB cable that is used for charging and file transfer.
https://en.wikipedia.org/wiki/USB_On-The-Go
https://www.amazon.ca/Micro-USB-OTG-Ada ... B00D8YZ2SA
USB Audio Player also supports UPnP/DLNA. So if your wifi is up to snuff, a micro SD card is not needed
