It is currently Tue Apr 24, 2018 6:55 pm
PostPosted: Wed May 24, 2017 11:36 am
I have an OPPO 105D... So, I'm thinking to buy the Sonica for a 2nd system... or another 105D... I would like to know your impressions about this "new dac".... Vs. your old dacs or the 105, thanks.
Speakers: Spendor S9e, Harbeth SHL5, Focal 1008be2, Focal 836W, Focal 806V
Amps: Pathos Classic One MkIII, Primare I30 & A30.2, McIntosh MA6900, HK 990, Rega Brio3, Rotel RA-1062, Rotel RMB-1066
Multi-player: Oppo 105D
DAP: Fiio X1II PSB M4U-1
PostPosted: Wed May 24, 2017 12:11 pm
I bought one to try a DAC with the ESS ES9038PRO chip (it looked like the most affordable choice). It has been in use for over a week in my main system. The strongest point of the DAC is detail, in this category it compares favorably with anything pricier I have owned in the past. The separation of voices and instruments is very clear and everything has a "wide" sound. So far I have only used the USB input and balanced outputs on the Sonica.
Being unbiased with gear I bring in to evaluate my only complaint so far is I find it a bit bright when partnered with revealing gear. The downside is both speakers I am using and one of the amps are very revealing. I would not bother pairing it with a Focal and class D amp setup for example.
My plan was to use it short term while I decide on a new DAC but it will be staying for a bit longer than anticipated. Overall it is a great value even when paired with more expensive gear.
Associated gear while testing the DAC
Martin Logan ESL 15A/KEF Reference 205
Luxman L-590A II/Modwright KWI 200
Audioquest Jitterbug + Diamond USB
PostPosted: Wed May 24, 2017 2:24 pm
Good review https://www.youtube.com/watch?v=raOXsK-Paoo
Turn on CC for english
PostPosted: Wed May 24, 2017 3:05 pm
Thanks. Improving my Cantonese..... :lol:
PostPosted: Sun Jun 18, 2017 3:11 pm
Anyone with the Sonica have medium-term updates on SQ / performance vs the 'usual' incumbents (Sim, W4S, Mytek, etc.)?
Much thanks!
PostPosted: Sun Jun 18, 2017 6:01 pm
I recently got a Musical Paradise MP-D2 and it is significantly better at a similar price. Not a positive comparison for the Sonica but it is still a great DAC. It did very well against the popular DACs though.
PostPosted: Sun Jun 18, 2017 6:15 pm
Thanks, James. As always very helpful. MP seems to be the continued value leader....
PostPosted: Sun Jun 18, 2017 6:46 pm
I worry about the long term build quality. My Chord DACs were built like tanks.
PostPosted: Mon Jun 19, 2017 1:35 am
Long term build quality of the MP or the Oppo? I assume you are referring to the MP DAC as Oppo build quality is almost always top notch.
