It is currently Sat Jul 21, 2018 11:10 pm
 Post subject: Marantz Scope
PostPosted: Mon Apr 03, 2017 12:05 pm
Does anyone out there know the brand and/or part number of the scope tube that was used in the Marantz 2130 Tuner ? Mine's gone sideways (literally) and my tech has no info (brand or otherwise) to try and find a replacement for it. Any info would be appreciated as well as where I could possibly find this holy grail.
Thanking you all in advance........
Axle.
 Post subject: Re: Marantz Scope
PostPosted: Mon Apr 03, 2017 12:28 pm
from the 2130 service manual, part number VB00235012
from another source; Hitachi/Toshiba 50TB31
PostPosted: Mon Apr 03, 2017 1:47 pm
Thanks for the reply !!! I found the Hitachi tube and part number you sent on another forum but can't find one yet. Would you know the brand name for the part number VB00235012 ?
PostPosted: Mon Apr 03, 2017 2:15 pm
sorry, that's all it says in the manual
PostPosted: Mon Apr 03, 2017 3:04 pm
From what I remember,you will have to search Europe, specifically Germany.I don't believe anyone in North America has them.Try Ebay in various countries.
PostPosted: Mon Apr 03, 2017 3:43 pm
Axle.
I had a 2130 with a scope that appeared broken; it displayed a large jagged line regardless if music was playing or not. Turned out some small capacitors on the scope board had failed. The repair cost a few dollars in parts, plus about an hour of labour. I suggest you ask your tech to look into that possibility, or find another tech who will. It's extremely uncommon for the scope tube itself to have issues.
PostPosted: Mon Apr 03, 2017 5:05 pm
Axle.
First: I would follow "Retro Audio" advice, and if no joy...
Second: Put your question to AK, http://audiokarma.org/forums/index.php? ... r&o=date&c[node]=134
They have more Marantz owners in that Forum, they might have an answer for you...
PostPosted: Mon Apr 03, 2017 10:14 pm
Axle.
Sounds like your tech has no clue. The fact that your scope shows some display means the scope tube is fine! Look for another tech.
PostPosted: Sun Apr 15, 2018 7:42 pm
Hi Axle,
It really does sound like an electronic fault you have. I would be checking the drive circuitry if I was your technician. I used to be authorized warranty for Marantz. That is a wonderful tuner.
-Chris
PostPosted: Sun Apr 15, 2018 8:55 pm
Get another tech. Preferably one that has experience with these units. I'm no expert but I have had at least three Marantz units with scope display issues. I got them all working.It is rarely the scope. The caps in the scope circuit should be replaced and the fault could be a transistor in that circuit as well. Regardless your unit needs an experienced tech. There is close to 600V in that scope circuit.Lots of heat and stress.
When you do get it running. Use the scope sparingly for longevity. They do fade away with use.
Chris is an expert!
