It is currently Tue May 22, 2018 2:19 am
Post new topic Reply to topic  [ 27 posts ]  Go to page 1, 2  Next
 Post subject: LP Storage
PostPosted: Mon Mar 20, 2017 12:55 pm
If you are looking for LP storage, are into design and have plenty of money you may like the following:
http://www.dwr.com/storage-shelving-bookcases/stacked-shelving-system/7421.html?lang=en_US&cyEmail=p.baillargeon@sympatico.ca&utm_source=Responsys&utm_medium=email&utm_campaign=20170321_SpringCleaning#q=stacked&lang=en_US&start=1
Not suited for lovers of granny type pine furniture.
 Post subject: Re: LP Storage
PostPosted: Mon Mar 20, 2017 1:49 pm
Pretty cool. The prices of the modular cubes seems reasonable enough until you scroll down to the bottom to see the really nice stuff: the Kai High and Kai Wide shelving. Yowza!
PostPosted: Mon Mar 20, 2017 2:09 pm
Thanks but Ikea and i get along well.
PostPosted: Mon Mar 20, 2017 2:11 pm
Build your own.
Cheaper, stronger (3/4 inch plywood) more pure storage. Home Depot cut all the pieces, just screw it together. Paint if you want.
PostPosted: Mon Mar 20, 2017 2:57 pm
The skinny legs and mitred joints, I don't know. Is there a weight rating in their specs?
PostPosted: Mon Mar 20, 2017 5:53 pm
It isn't Kai wood but it's less than 4k USD:
Home Depot for $289
Ariston RD 11 Superieur/Rega RB250 w Michell Tecnoweight/DV20X2H/Lounge Audio LCR MkIII/Dacmagic 100/Exposure 2010S2/AS Testaments/PSB GT1's
PostPosted: Mon Mar 20, 2017 6:08 pm
I have 2 of these I turned on their side which hold close to 1k lps
Currently $93 at Rona.
PostPosted: Mon Mar 20, 2017 6:44 pm
Just fyi. They're not meant to be sideways........... :wink:
PostPosted: Mon Mar 20, 2017 7:24 pm
Hi
The link shows a chair on wheels I like,it's not cheap though. Every time you sit on it ,you reminded you're at the dentist.
George
PostPosted: Mon Mar 20, 2017 9:03 pm
Trusting 1000 lbs to an Ikea Expedit is a major risk. Hope his gear wasn't under the pile of records. I've seen the Expedit close up and didn't trust it. The ones I purchased at Rona are more heavy duty.
PostPosted: Tue Mar 21, 2017 3:59 am
The other guys beat me to it but the weight of a thousand Lp"s or so is considerable.
I had a friend that does wood working as a hobby build me a stand to hold 1,500 LP's.
When I told him what I wanted he thought my specs were "overkill".
No such thing.
Nothing short of an earthquake with budge it. Ikea? Sorry,I'll have to pass.
PostPosted: Tue Mar 21, 2017 11:52 am
Hi
The Ikea Kallax (4x4) is fine as long as you follow a few guide lines assembling it. Add glue to the wood dowels ,install backboard,orient the assembled rack in such upright position so that the intermediate shelves running through the width, attach it to the wall behind with provided braces.
However you can eliminate a lot of risk by going with a (2x4) unit and place in on side,much more stable since it's not top heavy,then you can joint (mechanically by through bolts) another (2x4) to it standing,you can expand by interlocking the units.
George
PostPosted: Tue Mar 21, 2017 1:46 pm
No such thing.
This is Ikea and its just fine thanks...
PostPosted: Wed Mar 22, 2017 4:01 am
I don't know which Ikea unit I have, but its sturdy and cheap.
It depends on your budget, taste and practicality. The design of the unit I have can be easily modified to make it more than strong enough.
Securing to the wall in a couple of places helps as well. Having a 1000 lps fall on top of you would break more than your heart.
PostPosted: Wed Mar 22, 2017 5:37 am
I have a 2x4 Ikea unit, this was before they cheapened the design and made it much less sturdy. However, I saw online once a clever idea with the large Ikea unit meant to hold lots of records. The guy added 1x3" wood along the back of every shelf. The added bonus was that it is a stop for the records, so they all line up well at the front. The added wood substantially increases the strength. Could be used for any of those other similar shelve systems.
Actually, think I found it.
https://newrecordday.com/diy-ikea-kallax-record-shelf/
Users browsing this forum: Google Adsense [Bot] and 10 guests
