It is currently Sun Jun 17, 2018 10:05 pm
Post new topic Reply to topic  [ 151 posts ]  Go to page 1, 2, 3, 4, 5 ... 11  Next
PostPosted: Sat Mar 11, 2017 9:01 am
I've had great results with Bybee products when placed within cable lines, but this product is designed to be placed externally, near wires or on components or anywhere with a magnetic field for that matter... It comprises of Quantm crystals within a slender wooden box with felt underneath. They're currently specially priced at $90 usd each. Has anyone tried these? Does anyone know if these magic crystals lose their mojo over time? :P
PostPosted: Sat Mar 11, 2017 9:31 am
Read a review on these and the theory of how they function according to Jack Bybee seemed to make sense. The reviewer was initially a bit skeptical but
by the end of his assessment, he concluded that they do indeed 'quiet' the signal much as the other Bybee products do but externally by affecting the magnetic field associated with the signal. The reviewer insisted that he always discerned an improvement, however subtle. I wish I could remember where I saw this review. It may have been at the Bybee web-site. Bottom line is they do work but it was recommended that you use many of these to achieve maximum effect.
J.
PostPosted: Sat Mar 11, 2017 10:11 am
My Reference 3A Episodes evidently have Bybee Quantum Purifiers installed from the factory....which I guess lends some legitimacy to the Bybee product line. Personally, I remain skeptical of the Quantum Signal Enhancer....but who knows?
PostPosted: Sat Mar 11, 2017 10:18 am
J.
''Bottom line is they do work but it was recommended that you use many of these to achieve maximum effect.''
No wonder my amp manufacturer have 3 pcs in each amp. Think they wired in at input of the power transformers and 4 pcs at the entrance at each speaker.
90.00 seems like a good price, Partscoonexion have the at 120.00 each
PostPosted: Sat Mar 11, 2017 12:44 pm
That was acually the Partsconnexion special pricing for the 'new and improved' version. Think I'll pick up a pair to try under speaker cables and report back. They might work for resonance control as well atop components? Cost about the same as the HRS small plates. Should be an easy comparison..
PostPosted: Mon Mar 13, 2017 1:18 pm
I just bought 2 of these to try but unfortunately I have to wait for stock to come in.I will post my impressioins after I get these in my system.
Aaron
PostPosted: Mon Mar 13, 2017 3:49 pm
Aaron
Is it to late to cancel without loosing money ? I suggest you take a cold hard look at products that claim to use "quantum physics" before spending any money.
PostPosted: Mon Mar 13, 2017 4:09 pm
Hey its only money,worth trying in my books,I have heard bullets and they did make a difference in a high end system to my ears and everybody else that heard them.
Aaron
PostPosted: Mon Mar 13, 2017 5:35 pm
why do other wise smart men fall for stuff like this
PostPosted: Mon Mar 13, 2017 6:11 pm
perhaps the they've never seen one taken apart?
however I take this online pic with a grain of salt as my measurements were significantly different.
PostPosted: Mon Mar 13, 2017 6:22 pm
What are you measuring for the resistance reading ?
PostPosted: Mon Mar 13, 2017 6:31 pm
Really hope Mr Bybee sees this soon.
Appears to be a 10 cent Pacific carbon resistor that Bybee has tricked me with.
I do an ohm measurement soon to find out.
PostPosted: Mon Mar 13, 2017 6:42 pm
life lesson - if it seems to good to be true - it usually isn't true - just the name alone raises a RED FLAG in my book.
PostPosted: Mon Mar 13, 2017 7:22 pm
The term Quantum Crystal is a meaningless pile of BS. There is no such thing. Another example of Faith Based AUDIO.
PostPosted: Tue Mar 14, 2017 1:08 am
Snake oil sold by charlatans to dupes, been happening for centuries and still being perpetuated today by hi-end wire companies and others such as this guy. The more obtuse and jargon laden the advertising literature the more you can be assured it's BS.
