It is currently Tue Jul 17, 2018 10:55 am
Post new topic Reply to topic  [ 104 posts ]  Go to page 1, 2, 3, 4, 5 ... 7  Next
PostPosted: Tue Feb 28, 2017 8:46 am
Hello was wondering if anyone could recommend something that doesnt break the bank, but has a decent range for electronic music. Im ordering a T-amp from ebay, I need something modestly flat if possible that has a strong stereo image. I heard of tannoy reveal passives but havent seen them for sale ever around me I think. thanks for any help.
PostPosted: Tue Feb 28, 2017 8:49 am
What is your budget? That will help for sure. Everyones idea of "budget" gear varies wildly.
Sent from my SM-G920W8 using Tapatalk
Davidson Home Audio Designs
PostPosted: Tue Feb 28, 2017 9:31 am
Trutone Electronics in Mississauga is a Tannoy Dealer.
Probably pricey.
PostPosted: Tue Feb 28, 2017 9:40 am
These get good reviews:
http://www.wharfedale.co.uk/product.php?pid=76
PostPosted: Tue Feb 28, 2017 9:45 am
similarly,,Wharfedale Diamond 225.
Just bought these,,
http://www.stereophile.com/content/whar ... uOkcAOu.97
sounded far better than I expected.
PostPosted: Tue Feb 28, 2017 9:58 am
budget around 200 :evil:
PostPosted: Tue Feb 28, 2017 9:59 am
never mind then!
new or used?
sent you a pm
PostPosted: Tue Feb 28, 2017 10:16 am
Here's a couple that fit into your budget.
Yamaha NS-30X for $120:
http://www.canuckaudiomart.com/details/649336856-fs-yamaha-ns30x-speakers/
- 180 W
- 6 Ohm
- 92 dB sensitivity
Sony SS-K30ED for $200:
http://www.canuckaudiomart.com/details/649199789-sony-ssk30ed/
- 120 W
- 8 Ohm
- 88 dB senstitivity
No affiliation with either seller.
EDIT: ignore the Sony's. 10 Watts won't be able to really drive them.
PostPosted: Tue Feb 28, 2017 10:18 am
Budget $200/electronic music.......used PSB Alpha B1s.
PostPosted: Tue Feb 28, 2017 10:26 am
+1 great little speakers
PostPosted: Tue Feb 28, 2017 10:47 am
Energy C3 speakers, good speaker, made in Canada and you should be able to find a pair for your budget or less. As an alternative, the Energy C1 is almost the same speaker but with a smaller woofer and of course, for even less money.
PostPosted: Tue Feb 28, 2017 11:06 am
thanks for the opinions, ill keep a look out.
anyone have experience with the pioneer bs 22's?
PostPosted: Tue Feb 28, 2017 11:07 am
I'd recommend the PSB Century 300i or 400i. I previously owned the 300is, surprisingly good for the price. Check Kijiji, saw some there recently in the $80-100 range.
Robert
PostPosted: Tue Feb 28, 2017 11:33 am
ARE Audio from st John Newfoundland - google it - they are great !!!
Users browsing this forum: silverf0x and 1 guest
