It is currently Tue Sep 25, 2018 12:38 am
PostPosted: Wed Dec 07, 2016 5:27 pm
PM7000 is a Marantz entry level int. amp issued around 2000...my first int. amp actually...too many amps afterwards... it has been left in the corner collecting dust for 2 or 3 years...until recently I decided to pay it a visit...
For an elec gear of that age (14 years old), especially not be used for 2 or 3 years, a thorough clean and check is necessary. Besides, it has a minor issue, slight clicking sound can be heard from time to time, which I believe was the relay - need clean up or replacement.
I'm pretty sure this PM7000 is still in working condition even though it has not been used for 2, 3 years...some Marantz can live for ever. Why bother disassemble and do some stuff on it? Well, for starters, if I don't DIY on it, this thread will not be tolerated here by our beloved moderator...;-) Secondly, just like we maintain our cars, with proper maintenance, we can keep our gears in good state, and extend their serving life. And above all, PM7000 sounds decent, it's worth a re-visit.
For a Marantz of similar age or older, note followings:
-It has many wires from various boards connect to chassis ...if disassemble the machine, remember to connect ALL of them back to chassis before you turn on power...remember this!!! Take as much photos as needed to keep track these wires...
-Solder joints, especially the ones for connectors, and some "big" or "hot" parts...as time goes, either they "suffer" from tension or heat or bad quality, some solder joints might eventually go bad and cause "disasters"...Don't get me wrong, Marantz build quality is solid, but you cannot expect your machine to work forever without taking care of them ...;-)
So, my target is to:
-Clean the machine, including clean the relays;
-Recap as necessary;
-Re-solder some solder joints...
File comment: Power caps are NCC, not PHILIPS as said by http://www.tnt-audio.com/ampli/marantzpm7000_e.html
File comment: Top right/left you can see some black wires connect to chassis via screws
PostPosted: Wed Dec 07, 2016 5:45 pm
Add one photo showing one wire connect to middle of the chassis...
File comment: One wire connect to middle of the chassis...
 Post subject: Power board
PostPosted: Wed Dec 07, 2016 6:29 pm
On power board:
-Recap elec. caps;
-Clean relay
Remove back panel and front panel...put their screws into their own bags...even though most of the screws are the same.
Maybe due to flux residual, the board is a bit "sticky" - dust cannot be easily cleaned, will wash and clean after recap.
On the caps labeled their manufacture date, e.g. one of the cap marked "0231" means 31st week of 2002...so, this PM7000 was made in 2002 actually ;-)
-- 08 Dec 2016 02:41 --
Power board recapped...cleaned.
Power relay top cover removed, contact point cleaned...
File comment: Back panel removed...
File comment: Put screws of each section into bags...will make life easier when putting them back
File comment: Power board removed, caps labeled manufacture date 2002
 Post subject: power board
PostPosted: Thu Dec 08, 2016 2:05 pm
Amp module removed from chassis
-Recapped;
-Relay cleaned;
-Solder joints enforced...and all cleaned...
File comment: Before cleaning
File comment: Amp module removed...
File comment: Recapping...
File comment: Before cleaning, transistors' solder joints dirty flux residual
File comment: top side cleaning
File comment: Top side cleaned
File comment: Back side cleaned
 Post subject: Other boards
PostPosted: Fri Dec 09, 2016 5:42 am
Recap the speaker protection board...only a few small caps.
No recap for input, tone, volume control...just cleaning, and re-solder the connectors
File comment: screws and parts organized into bags...
File comment: Speaker board recapped
File comment: Speaker protection board...cleaned and resoldered
File comment: Input board
File comment: One of the input boards
File comment: Tone board
File comment: Only transformer inside chassis now...
 Post subject: put it back...
PostPosted: Fri Dec 09, 2016 7:26 am
-Put all back into chassis...restore the GND wires...
-Double check the wires connected correctly...
-Don't connect power to amp board yet, power on, check power supply correct...then turn off;
-Now, connect power to amp board...
-Power on, check DC output, bias...(don't adjust bias yet)
-DC output ok, then connect speaker and enjoy the music....
-After many hours (or days) ...new caps need break in and stabilized... then adjust bias as necessary
Done!
File comment: power board first..
File comment: input boards
File comment: almost done
File comment: All put inside...
 Post subject: Calling for Marantz SR1*
PostPosted: Tue Dec 13, 2016 1:20 pm
Anyone owns one of Marantz SR19, 18, 17, 14?
PostPosted: Tue Dec 13, 2016 4:30 pm
Nice job Frank, that amp should be good for many more years to come. After such an extensive rebuild, I wouldnt dream of bringing the amp back online without a dim bulb tester, you are a braver man than I :)
PostPosted: Tue Dec 13, 2016 5:36 pm
After some DIY projects, you know pretty much the tricks...and the more you have built, the more cautious you will become...I would not dare "brave" after all;-)
Point of this thread is - machines need maintenance to keep them in good working order, and for some machines, to prevent "unnecessary" disastrous things from happening...there is a reason I'm calling SR1*
PostPosted: Wed May 10, 2017 5:20 pm
How bad an old relay can be...
PostPosted: Thu May 11, 2017 3:19 am
Nice work Frank. Inspiring.
Now when you say "resoldered"...does that just mean "reflowed"?
For example...your 'Speaker board' pic.
I ask because I am contemplating tackling my Kenwood KA9100 this summer
PostPosted: Thu May 11, 2017 6:22 pm
Have to be clear that the relay pictures above are not PM7000's, it from a very old Yamaha power relay...
Yeah, normally I use solder wick to remove the old solder clean, then solder ... not work "on top of it" ;-)
Necessary? It depends on which brand/model, and where...
-I found Marantz gears tends to have solder joint issue in some models...I have worked on many brands' old gears, I found Naim, Linn...those UK gears normally have very good solder quality.
-About where...places where suffer from heat, stress, such as connectors on PCB...as time goes, it will become a problem.
Below are some pics from a Marantz SR17 I'm working on trying to fix (I like Marantz SR1* AV amps, personally, I love their sound more than Denon 5805)...I went to visit a friend and he has a SR17 and he loves it, I told him that SR1* is tend to have solder joint issue and will cause amp blow up. I offered to help him do some maintenance ...but he did not take it serious...and now I'm working on fixing it...
Again, like we maintain our cars, some audiophile gears also need attention or it will die ;-(
Back to your machine, it might or might not need reflow...if their solder quality is good and you are not sure you can do better, then don't...
Disclaimer:-)
Hope I did not upset anyone...
I'm from an amateur perspective, even though I majored in EE back in university, current job is not relevant... I'm still a Marantz fan...most of my brand gears are Marantz.
PostPosted: Sun Jun 11, 2017 10:37 pm
Disclaimer:-)
Outstanding detail with photos Frank, I have a PM7001 and it seems fine and will try to remember this rebuild just in case I try my first ever attempt on doing maintenance...once something quits working of course otherwise I may make it quit working by mistake :lol:
PostPosted: Mon Jun 12, 2017 7:31 am
If you have DIY experience, doing a task like this is easy - "make it quit" never came to my mind...just need patient and be careful. Follow or create your own practice, such as bag and label screws and small parts, using the stuffs right for you such as solder wick...take a lot of photos to keep track of the parts and wires - this works well for me as I normally clean/wash the boards and this process could take days, and I don't have a good memory...
This kind of maintenance does need DIY experience and some knowledge...you can build up the skills playing some already dead or "doesn't matter" gears...
PostPosted: Mon Jun 12, 2017 8:42 am
(regarding cleaning relay contacts and leaving a smooth clean 'still plated!' surface behind)
Canadian tire now has a regular line of 4x 11"x8.5" sheets of 2000 grit sandpaper, in the automotive painting section. Decent quality 3m product, best price around, available in 500 locations, or thereabouts. FYI for all interested, kinda thing. Probably in their automotive 'Parts Source' stores as well.
(Ultra fine grit is best for relay and switch contact jobs. Critical, actually)
-- 12 Jun 2017 12:50 --
I tend to reflow with new solder, then use a solder pump to clean it out, then get to the re-soldering. I've almost exclusively used a solder pump for 30 plus years, and I even have two desoldering stations. I don't use either one of them, as they clog up and need maintenance. I just reach for the solder pump and it works every time. The solder pump needs cleaning but it is ultimately more reliable and less time consuming, IMO.
The desoldering stations are more there for some critical stuff that might come along, where things are a bit more stubborn than what a solder pump can deal with. Which is very rare, once you master the use of a solder pump.
