It is currently Wed Aug 15, 2018 2:38 am
Post new topic Reply to topic  [ 99 posts ]  Go to page 1, 2, 3, 4, 5 ... 7  Next
PostPosted: Thu Oct 22, 2015 7:26 pm
This is an on-going "story" about my adventure with Adcom GFA535. Just got it recently from ebay, and is in progress give it a new life.
People have mixed feelings when it comes to old gears, how long and how well it can perform, is it stable , is there any hidden problems, will the parts be available, and etc... I really wish I could think things through before dived into the marriage, just kidding...but getting old audio equipment need guts, and the spirit of DIY.
Back on the topic, I did study this amp for a while, and I am determined to transform it, that's why I put this thread in DIY section.
To make it more clear, I format following Q&As:
Q: Why GFA535?
A: Some says it was designed by Pass.
Q: Did Pass design GFA535?
A: Strictly speaking, NO. Pass did design 555, Adcom derived two down scaled versions 545, and 535.
Q:What's the difference between 555,545,and 535?
A:Power and chassis dimension mostly. 200W, 100W, and 60W.
Q:Again, why GFA535?
A:It is a well designed amp (Pass blood), it's the cheapest, it has more potential comparing with 545 and 555...
Q:Why 535 has more potential?
A:It has the same PCB as 545...
Progress:
-After got the amp, opened cover, and did a visual check, found a broken fuse, no other noticeable issues...ordered a batch from mouser.
-Replaced all fuses with new ones, power on, running for a while and do some measuring and adjusting.
-Plan for next steps....
-- 23 Oct 2015 03:41 --
Add a back view photo...I hate its binding post.
File comment: It has been taken good care of by previous owner.
File comment: Replaced broken fuse, power on, and do some measuring
File comment: Measured +/- voltage, so it should be 52V after filtered.
File comment: Bias voltage adjusted
File comment: Heat sink temperature after running 1 hour
File comment: Transformer temperature after running 1 hour or so
PostPosted: Thu Oct 22, 2015 7:43 pm
The binding post requires low gauge speaker bare wires...
PostPosted: Fri Oct 23, 2015 1:51 pm
I still own my 535 – 20+ years and still working. Replaced the set of 8 crappy binding posts with just 4 quality ones. And removed the A/B switch from the signal path (kept the buttons but they do nothing). Great little amp that punches well above its price range.
PostPosted: Fri Oct 23, 2015 2:48 pm
I have two of them. I got the first one to replace a 4B. I thought it would be downgrade. I'm missing the slam of the Bryston but the sound quality is on par. At the time I ran a pair of Stratus Gold and no problem driving a 4 ohm load. Superb amp conservatively rated at 60 WPC.
PostPosted: Fri Oct 23, 2015 3:50 pm
This is a very good amp. My friend has one and he says it's always turned on - it's been running without a burp for 22+ years.
I've owned the 555 and 545, they're all excellent amps, built like tanks and very decent SQ.
I wouldn't be in a big hurry to change anything on it. 8)
PostPosted: Fri Oct 23, 2015 4:50 pm
Remove A/B switch is also part of my plan...
PostPosted: Fri Oct 23, 2015 4:54 pm
Good luck on your start of modding this fine amplifier. I have done 6 of them which I have had over the years. Honestly I only changed a handful of parts which were 4 diodes and 8 capacitors if memory serves correctly. I also tried several resistors but they didn't appear to make any sonic difference. Total of around $30 in parts. You have the Mk I, which I had also swapped the transformers from a Mk II into them as they are 10VA larger.
Good luck, J
PostPosted: Fri Oct 23, 2015 5:11 pm
-Parts on the way...some will need one week or two...
-Collected data from power transformer venders...535 has a very slim body, hard to find a suitable high VA transformer...well, transformer can wait.
What I did tonight:
-Replaced RCA inputs
-Removed amp boards with sinks, gave them a through bath...prepare for recap and other parts replacement
File comment: you can still see water on it...
PostPosted: Fri Oct 23, 2015 5:45 pm
Thanks for your advice.
The reason why I want make any changes on it, like I said, bring it to its full potential, that should be fun...
-- 24 Oct 2015 01:58 --
Good luck, J
Yes, resistors are not aging the same as elec. caps. If just bring the amp to spec, I will just do recap and probably diodes like you did...
The transformer on my mind will be much bigger...535 comes with 300VA (150VA * 2) I believe, and I am thinking about 600VA. As I am planning to bring its power to 100W per channel, which need transformer 200VA * 300%.
GFA545 claimed 100W*2 output, but transformer is around 400VA, which I consider is not enough.
The problem with 535 is the internal height of the chassis is around 70mm, and most 600VA is taller than that...bummer...but I have talked to Richard from SumR, he can do a 600VA under 70mm, with a bigger OD and lower height core I suppose.
Thanks for the good luck blessing, I really need it ;-) Have a nice weekend!
PostPosted: Fri Oct 23, 2015 6:20 pm
When I went through all of mine I only had one of the six which actually needed an electrolytic replaced, all of the others measured in spec for capacitance and leakage. The ones I upgraded were all in the signal chain. I found increasing the main power supply caps capacity actually made the amp sound darker, even with 2 smaller bypass capacitors of 47uF and 0.1uF across each.
Good luck fitting larger transformers in the chassis, even if you get one that fits in height the changes to the other dimensions for that VA rating will bring the windings about 3/4" closer to each board and possibly to the caps. It will run hotter due to the idle current losses in the windings as well. Make sure it is shielded as all of the jumper wires used are plated steel along with all of the small signal diodes.
J
PostPosted: Fri Oct 23, 2015 6:49 pm
J
Thanks again Jaxom. The transformer will be shielded if I go for a bigger one...
PostPosted: Sat Oct 24, 2015 5:22 am
Frank,
I believe the Adcom is DC coupled.Rock solid circuit.
The only circuit mods I know of are the bias adjust smoothing cap and the feedback shunt cap.
A dude in the US tart's up the 535/545/555 for the pro studio guy's.
PostPosted: Sat Oct 24, 2015 5:27 pm
sasquatch wrote:
Frank,
Thanks Gary.
535 is indeed a good amp for the price, and solid too. I have fixed/mod some old amps, some of them are also classic and among stereophile top 100 hifi products list, and I probably love 535 more than others.
Actually, I have listened 535 for a while, I reserved my comments on 535 as it's subjective, system dependent, and probably not correct - about 10 years screaming, yelling family life, I lost my confidence in hearing.
Well, I guess it's not a crime to speak out personal opinion, as I did get some canuck members worried. Again, 535 is a good amp, otherwise I won't buy it. In a transparent system, I found it sounds a bit dry/thin, a bit lack of musical, grounding need some work also... I am picky on 535 for sure - as I believe it can do better, besides, I must have OCD, thinking about 30 years elec. caps inside my amp could drive me crazy ;-)
More important, DIY is all about fun, and I value the process more than end result. Having said that, I do not take any DIY adventure blindfolded and unprepared.
PostPosted: Sat Oct 24, 2015 8:08 pm
Only have time during nights after children went to bed :(
Now the RCA part is completed...
PostPosted: Sun Oct 25, 2015 7:40 am
Frank, from my limited knowledge of circuits, what you put in seems like a ground lift.
Was it there before? Otherwise what is the reason you put it in?
