It is currently Fri Jul 20, 2018 2:40 am
Post new topic Reply to topic  [ 59 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Pass ACA Builds
PostPosted: Tue Sep 08, 2015 8:47 am
Have done some ACA builds for friends, nice little class A amp. Thanks to Mr. Pass
-- 08 Sep 2015 16:55 --
Metal work on front panel
File comment: Power switch installed (ALPS push button switch)
File comment: Metal works on front panel done
File comment: Cut front panel hole, and tapping
 Post subject: Re: Pass ACA Builds
PostPosted: Tue Sep 08, 2015 9:06 am
Bias adjustment and finished the mono blocks
-- 08 Sep 2015 17:14 --
Transformer version...picked up the transformer from our local factory
Metal work on back panel...
PostPosted: Tue Sep 08, 2015 9:23 am
Another transformer PS build...as usual, got the transformer from local factory on my way to work...
PostPosted: Tue Sep 08, 2015 11:52 am
Another stereo build using 2109 (220mm(W), 90mm(H), 257mm(D)) chassis
PostPosted: Tue Sep 08, 2015 12:21 pm
Very nice work Mr. Wang. Very nice.
PostPosted: Tue Sep 08, 2015 12:53 pm
WOW nice work! Looks super professional. Just wondering what it costs to build these amps with case? Also what are the specs?
PostPosted: Tue Sep 08, 2015 1:09 pm
Thanks. For specs, check Nelson Pass's article:
http://www.diyaudio.com/forums/diyaudio ... p-1-a.html
The cost varies depends on the enclosure, and power supply... Chassis is always a headache for DIYers.
PostPosted: Tue Sep 08, 2015 1:10 pm
As you can see by my post count I am rarely moved to comment but, holy cow - very nice work!
PostPosted: Tue Sep 08, 2015 3:21 pm
Thanks. I just have a drill press, and all I did was drilling holes. A lot of people can do better than that;-)
PostPosted: Tue Sep 08, 2015 5:25 pm
Also tried using Amplimo transformer (Plitron has minimum 250CAD online order restriction) bought from Holland...cheaper and sound-wise also good.
From Plitron website, you can also find Amplimo plate amplifier...they got to have some connections...
PostPosted: Wed Sep 09, 2015 9:13 am
Nice builds!
How did you do the engraving on the front plates?
BTW you may also want to try getting your transformers from SumR transformers. They are also local (so no shipping costs) and will build custom with no minimum.
I've used them many times, Richard is a great guy.
PostPosted: Wed Sep 09, 2015 9:23 am
dazed2 wrote:
Nice builds!
Just metal sticker...
Thanks, I have came across Sum R transformer...Plitron is on my way to work;-)
PostPosted: Wed Sep 09, 2015 12:54 pm
Those look great. Where do you get the kit? Or plans for the kit?
PostPosted: Thu Sep 10, 2015 7:11 am
I collected the parts from various sources, e.g. digikey, Newark, mouser, Parts ConneXion, takefiveaudio...and etc
PostPosted: Sat Sep 12, 2015 6:26 pm
Soldering an ACA tonight for an European friend, write down something hope could help your build...
Tips:
-If you are using a chassis without pre-drilling/tapping holes, use the blank PCB to position the drilling holes before soldering...;
-If you are not sure about the components, measure the components before plug them into PCB;
-Use a blade or sand paper "clean up" components' legs and wipe clean before put them into PCB...this will facilitate soldering and help forming a strong binding. Even new components, you know, sweat, grease, dirt and etc during handling;
-Follow from lowest to highest sequence, well, you don't have to, but this could help achieve a better looking result;
-Lift low watts resistors a bit above PCB to facilitate air flow, just a bit...for other DIY projects' PCB, this might not apply, depends ...
-Lift high watts resistors above PCB, e.g. 0.47R/3W, 0.68R/3W, they are hot...
-- 13 Sep 2015 02:28 --
You don't have to follow the sequence ... I put ZTX450 and SK170 lower than 10uf caps, therefore I solder them before 10uf caps
