It is currently Tue May 22, 2018 7:17 am
PostPosted: Fri Sep 20, 2013 11:14 am
I am trying to choose a speaker wire for my Tannoy 15" Red speakers. I managed to get the 4-pin Tannoy plug that plugs into the
connector on the drivers. This connector has an opening of about 8-10mm.
I was considering to use Van Den Hul wire between the crossovers and the drivers but VDH is not easy to find in Canada. Instead I
am trying to choose between Mogami 2921 4 x 14AWG conductors and Mogami 3104 4 x 12 AWG conductors. I am leaning towards
Mogami 2921 (which has a outer diameter of 11.3mm) and want to make sure that 14 AWG is enough for the bass LF section. Can
anyone care to comment? Is Mogami a good choice and is 14 AWG sufficient?
PostPosted: Fri Sep 20, 2013 12:10 pm
I would go for the Belden 9497....http://cheaptubeaudio.blogspot.ca/2009/ ... -9497.html
PostPosted: Fri Sep 20, 2013 4:50 pm
libor wrote:
Thanks Libor. I did a little research and like VDH it doesn't seem to be easily available either.
PostPosted: Fri Sep 20, 2013 5:01 pm
I know, maybe the best is to order it from Japan...at least you will only buy by foot, not like 1000' spools...
Users browsing this forum: allander and 11 guests
