It is currently Mon Aug 20, 2018 3:00 am
PostPosted: Thu Jun 13, 2013 5:12 am
hi there,
looking for standmount speaker recommendations for my pc/desktop using an old Luxman R113....so 35 watts only at 8 ohms (guessing close to 70 at 4ohms)
no dac as of yet, will probably get an inexpensive one later, something from fiio or schiit
was thinking of either KEFQ300 or B&W 685's
all input appreciated, please and thanks
PostPosted: Thu Jun 20, 2013 6:32 pm
I cannot vouch for whether KEF and Luxman are a good match, however, I can say that I am very impressed with my new KEF R100 speakers. Purchased for precisely the same setting as you - office system, near-field listening. That Uni-Q driver seems to a good fit for such a task. I have them mated to a NAD C352, NAD C542 and also a Sonos unit. Great detail, enjoyable at low volume listening, tight bass. Just playing with positioning now.
PostPosted: Thu Jun 20, 2013 6:46 pm
Are you going to be listening from your desk primarily? Are you planning on listening from there in the future? M audio has some very nice near field speakers, no amp needed.
PostPosted: Mon Jun 24, 2013 5:00 am
desk only
-- 24 Jun 2013 16:26 --
kefr100's are way above price range
PostPosted: Tue Jun 25, 2013 5:30 pm
Yes, there is a price diff. I was only commenting that KEF's driver design, whether Q or R series, seems well suited to the task.
PostPosted: Fri Jun 28, 2013 4:54 am
Kef would be a better choice than B&W.
With the R113, thatll sound stunning.
UNITY AUDIO
PostPosted: Fri Jun 28, 2013 6:17 am
Hello
I had a set of Monitor Audio Radius 90's I used with a L-501 and I thought they sounded great together. Can't say with the R113 though as I only had Paradigm Monitor 9's hooked up to it when I had it.
Good luck, J
Users browsing this forum: No registered users and 11 guests
