It is currently Fri Apr 20, 2018 9:46 pm
Post new topic Reply to topic  [ 41 posts ]  Go to page 1, 2, 3  Next
PostPosted: Tue Apr 30, 2013 7:46 am
the age of an amplifier when a recap is required
5 years
7 years
10 years
15 years
20 years
or more
PostPosted: Tue Apr 30, 2013 8:01 am
Electrolytic cap life is dependent on the running time and the temperature that the caps reached.
Sitting beside a rectifier tube with very little ventilation is a classic design flaw that cooks the filter caps fairly quickly.
All the old paper and mica caps (1950's and earlier) should be replaced regardless.
What amp and what vintage? :)
PostPosted: Tue Apr 30, 2013 8:05 am
10 years old mcintosh solid state
PostPosted: Tue Apr 30, 2013 8:22 am
Nice stuff! I would leave it alone unless you hear 60 or 120Hz hum.
PostPosted: Tue Apr 30, 2013 8:26 am
Thankyou
Just what I wanted to hear
PostPosted: Tue Apr 30, 2013 8:32 am
If there are signs of leakage or bulging, then replace them regardless of age.
PostPosted: Tue Apr 30, 2013 10:49 am
+1
Forgot the visual inspection aspect :wink:
PostPosted: Tue Apr 30, 2013 10:59 am
The technical answer,
most good techs would suggest every 10 years to keep the
amplifier running at optimum as it was built biased and
designed to as new specs would be.
The realistic answer,
1/ when your ears tell you its time
2/ when your wallet says you can afford to
or
3/ the amplifier makes both 1 and 2 moot points
with a painfull silence or an irritating buzz
PostPosted: Tue Apr 30, 2013 11:13 am
Yep, just had one go down in terrible silence. Not nice at all. :cry:
IF IT DON'T FIT.......FORCE IT!!!!
PostPosted: Tue Apr 30, 2013 11:17 am
I think many will recap when it is not necesary. I wanted to recap my Sugden amp, based on many suggesting that it needed to be done given its age of 23 years. I took it to my tech, and he said to leave it alone, caps were good. I had my doubts, so I contacted Sugden directly. The advice was the same - very likely nothing wrong with the caps. Not suggesting at all that recapping is not required for many amps, but I think its done in many cases where its not required.
PostPosted: Tue Apr 30, 2013 12:07 pm
Has anyone had experience with Rowland Model 12? They're absolutely silent but I wonder if I should pretend I know what I'm doing and open them up?
PostPosted: Tue Apr 30, 2013 12:20 pm
Most good techs I know would say "if it ain't broke, don't fix it." They would test it using appropriate equipment, and if it's running in spec, with no visible potential points of failure (i.e. the bulging caps thing), that would be it - enjoy.
PostPosted: Tue Apr 30, 2013 12:22 pm
I find it hard to believe that caps, even in storage, would last 23 years. But perhaps storage is harder on a cap than running it?
PostPosted: Tue Apr 30, 2013 12:51 pm
+1.
Audiophiles are tweakers by nature, and caps are just another tweakable object. Replacement is often more of a feel good thing than about bringing any real improvement.
PS caps in my Threshold S/150 are original, going on 30 years. The amp looks and sounds fine. Never turn it off though, which helps with the longevity.
PostPosted: Tue Apr 30, 2013 12:52 pm
Actually I was always under the impression that leaving it stored for extended periods of time then firing it up cold is hardest on them . Hence the Variac.
I think the concept of the degrading over time is not something one could argue against and appear sane. As much as I tend to lean on the side of it aint broke don't fix it
the concept of swapping the caps after 10 years especially on the power side of an amp
is sound reasoning. When that reasoning is to have the amp always performing as new and at its optimum as it did when new.
Ever wonder how many people descide to make changes , one of the asides of an aging amp and caps loosing grip is a lessening of power and and earlier clipping that undeniably
leads to fatigue when listening...........that leads to usually the for sale sign instead
of a re capp.......
Users browsing this forum: No registered users and 12 guests
