It is currently Sat Sep 22, 2018 12:56 am
Post new topic Reply to topic  [ 74 posts ]  Go to page 1, 2, 3, 4, 5  Next
PostPosted: Wed Jun 02, 2010 7:45 am
Are there any Jolida dealers in Canada? I want to get a Jolida amp but doing a search on google for Jolida canada didnt help much. Any ideas?
PostPosted: Wed Jun 02, 2010 8:05 am
There's one down this way. Electronic Depot on Lundy's Lane... Niagara Falls
They have some stock on display and seem quite helpful.
I haven't bought from them yet personally so I can't specifically vouch for them, but I haven't heard any negatives about them either.
Cheers
Continuing the never-ending search for great music!
PostPosted: Wed Jun 02, 2010 8:21 am
Hobopaul here on CAM is a dealer out of Winnipeg. Great guy to deal with.
PostPosted: Wed Jun 02, 2010 8:23 am
I've dealt with Hobopaul too. Excellent customer service and a great guy to boot.
PostPosted: Wed Jun 02, 2010 9:42 am
Omer at Oz Enterprises used to carry Jolida and he is a good guy (based on my previous dealings...)
info@ozenterprises.net
PostPosted: Wed Jun 02, 2010 10:05 am
the MAC Group, Ottawa
http://www.themacgroup.ca/wp/?page_id=225
PostPosted: Wed Jun 02, 2010 10:09 am
Isn't his user name Cableguy on here?
PostPosted: Wed Jun 02, 2010 12:22 pm
Wao thank you for the prompt replies :) Ill get in touch with them then as I really want to get a 1501RC or at least a 102B. Ive read wonders bout these two int amps.
PostPosted: Wed Jun 02, 2010 12:54 pm
If you're a bit flexible with your wallet, go for a 202A. These EL34 tubes sound sweet.
Dan
PostPosted: Wed Jun 02, 2010 1:27 pm
Decisions decisions, so which jolida product under 1000 do u think would be best? I listen to a little bit of everything and a remote is a must. Thank u.
PostPosted: Wed Jun 02, 2010 1:35 pm
This is a good question. I've owned the 502 before and it was thoroughly satisfied with the sound quality, especially once I upgraded the tubes. It was over the 1k mark, though.
What do you guys think is the best sounding Jolida?
PostPosted: Wed Jun 02, 2010 1:41 pm
Although Jolida offers a wide variety of products , the 202A and 302BRC are the sweet spots in the line. They can also be modded which takes them to another level.
For the OP, you cannot go wrong with the 302BRC as it comes with a remote control. It'll set you back a bit more than $1000 but you won't regret it 3 months later.
Dan
PostPosted: Wed Jun 02, 2010 1:50 pm
Awesome thank you for the responses. I just spotted a 302brc here in canuck so Ill see for how much I can get it. Thank you ;)
PostPosted: Fri Jun 04, 2010 8:38 am
+1
8)
PostPosted: Fri Jun 04, 2010 10:05 am
I've owned a 202, 302, 502. Currently looking to get a 1501. It comes down to speakers and music. If you need low end, you'll want to go with a 502. If you want something on the sweet side, go 302. If you need power, take the 1501.
Users browsing this forum: Google [Bot] and 3 guests
