lesjames wrote:
You room is a fairly good size. How far away from your
speakers is your listening position?
Average blue book value in US dollars is $420.00 for
Mite and Mite T.
Low vaues on mite is $240.00.
Low values on Mite T is $160's
Highest value was 600.00 but 600.00
is out of line and was only 1 sale all others were
much lower.
All the best Les
Wow... Thanks for finding that for me.
Are those new prices? Because I have not been able to find them listed for anywhere near that around Ottawa. Maybe I need to order online..
MPAVictoria
-- 30 Mar 2010 22:11 --
Mite and Mite T.
much lower.
All the best Les
Oh and my speakers are about 8 feet from my listening position.
Thanks again!
-- 30 Mar 2010 22:12 --
Audiofils wrote:
You may want to buy bigger speakers and for the same budget, consider a floorstander instead (Qyuad 21L or Monitor RS5) and they will be easier to drive too. Large room, small relatively inefficient speakers, not a combo I would opt for unless you are in love with the sound of the Mite.
Unfortunately the Girlfriend has vetoed floorstanders. Apparently they don't go with the decor.
