Chuck Lee wrote:
Not so much "where" but why?
Granite is a material that rings, it doesn't damp.
If you put your amp on it and use spikes any miniscule amplifier vibrations will travel down the spikes hit the granite and be sent back up the spike to the amp.
Granite has weight, which is the main thing. The problem I think is not to isolate the amplifier from itself, I just don't see an amp, even a tube amp, "ringing" and sending reflections back to itself. IF there's any sound from an amp, such as from an output transformer with slightly loose coil, then that is creating an astronomically greater "disturbance" to other parts of the amp than any reflection of such. I think what DOES matter is isolating the amp from the speakers, and anything to solidify the placement of an amp with its always somewhat microphonic input tubes will improve the sound.
It's been said that an amp and turntable should be to the side of the room, outside the focus of inward pointing speakers and the sound field, rather than between them where it gets energy from the corner effect and from direct reflections from the back wall. I find I have far less problems with rumble and feedback with the turntable off to the side rather than between the speakers, so that's a litmus test for what the amp would be hearing.
I hope this is considered on-topic, my comments are related to damping the amp and how RITA is being placed in her shelving.
