cpalfeni wrote:
Hit up your friends, and see if you can borrow another preamp and/or phono pre. A simple switch out would be the easiest first off, (to see if it's those units that are contributing to the problem). It just saves you setting up the table before eliminating those components as potential problem contributors. I found personally that the phono pre is a huge variable, and you basically have to find one that fits your system/budget and has synergy with the rest of the stuff. I personally like tube phono pre's myself. If it still sounds poor with a different (and hopefully higher end unit(s), then the tt is more of a suspect. gl.
One of the more helpful replies.....
Ignore the unhelpful replies about digital vs. analogue. There is something wrong if your CD player sounds better than your analogue rig.
You should not have to change your turntable.
As more helpful members have suggested, it could be a set-up problem. if correct set-up (alignment, weight, VTA, etc.) doesn't do it, then you should start looking at the cheap cartridge and phono stage, as they are the obvious things to change for improved performance. Find someone who knows how to set-up a turntable properly, and can offer advice on where to make improvements without diving too deeply into your wallet.
