Canuck Audio Mart
It is currently Fri Nov 20, 2009 3:05 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2, 3  Next
 Post subject: Weiss DAC2 resellers?
PostPosted: Tue Jun 23, 2009 12:40 pm
Can anyone please recommend me good reputable sources/stores to buy a Weiss DAC2?
Thanks.
 Post subject: Re: Weiss DAC2 resellers?
PostPosted: Tue Jun 23, 2009 3:53 pm
Try:
Planet of Sound
1194 Bank St.
Ottawa, ON, CANADA
K1S 3Y1
613-731-4434
info@planetofsoundonline.com
PostPosted: Tue Jun 23, 2009 5:14 pm
A dealer in Ontario just posted a classified for this dac...
PostPosted: Tue Jun 23, 2009 11:50 pm
Thanks guys. I will check them out.
PostPosted: Wed Jun 24, 2009 8:02 am
Audio Twk: just curious, have you heard this DAC? if yes, what did you compare it to and what are your impressions?
PostPosted: Wed Jun 24, 2009 8:11 am
I do believe My Kind of Music in Toronto, is an authorized dealer of Weiss products.
They are located in central Toronto...(Parking can be a bit of a challenge depending on time of day)
Oh yes, regarding performance, one of the very best.
Francis R.
PostPosted: Wed Jun 24, 2009 12:56 pm
The other DACs in my short list are Linn Akurate DS and Ayre QB9. Heard them although not side by side. IMO the Akurate has a very neutral well controlled and defined presentation, no particular highlights across the band just smooth and easy. The Qb9 is very detailed and highlights the upper register more than the other. The DAC2 fits more in between the two with a little midband emphasis, very easy to listen to.
PostPosted: Wed Jun 24, 2009 1:03 pm
Francis R.
Yes, John is a nice fellow. Had no clue he carries them. Seems most of the dealers don't list them in their site (that's why I kinda ask for help here). Thanks for pointing that out.
PostPosted: Wed Jun 24, 2009 1:37 pm
At this level of converter you owe it to yourself to also check out offerings from DAD, Prism, Pacific Microsonics, Metric Halo, Mytek, DCS, EMM Labs, Apogee, Lavry, Grimm and Forsell. The used market may be your best friend with many of these though.
The DAD AX24 is the best I have ever heard but when you are talking about this level of the converter it really boils down to personal preference as all of the above offerings are used in recording studios worldwide.
"What good is audio gear if you don't have the music to feed it?"
 Profile E-mail
PostPosted: Thu Jun 25, 2009 11:41 am
Thanks for the list Pneumonic. The Lavry, Apogee and the EMM labs were considered in my search. The DAD is used in Telarc's recordings, is there anywhere I could listen to this unit in Toronto?
PostPosted: Mon Oct 05, 2009 11:37 am
Excel Stereo - talk with Lawrence, great guy to deal with.
He's technically very knowledgable as well since he also does repairs and modifications.
PostPosted: Mon Oct 05, 2009 12:09 pm
If you're considering pro audio DACs, I'd add the Universal Audio 2192 to your list (street price around CDN$3500). The analogue output stage consists of discrete transistors rather than the usual off-the-shelf opamps. It's also an ADC and a master clock.
 Profile E-mail
PostPosted: Mon Oct 05, 2009 12:47 pm
I picked up my Weiss from Excel as well. Highly recommend dealing with Lawrence. :D
John
PostPosted: Mon Oct 05, 2009 5:37 pm
Indeed, Joel.
The UA is a VERY worthwhile DAC to check out. And supremely versatile too in addition to apparently being state of the art sounding.
Also add Cranesong and Prismsound to the list. I listened to a Hedd 192 at a studio this past weekend and wow ........
 Profile E-mail
PostPosted: Wed Oct 14, 2009 7:45 pm
Same here. Lawrence is a pleasure to deal with. I am really enjoying the DAC 2 in my audio set up.
Users browsing this forum: dr.joe, Stark and 0 guests
