It is currently Sun Jun 24, 2018 4:49 am
Post new topic Reply to topic  [ 144 posts ]  Go to page 1, 2, 3, 4, 5 ... 10  Next
PostPosted: Sun Dec 14, 2008 11:47 am
In this first installment I want to share the design goals I used to reach the final design for this new interconnect. I will also give some details of how the final interconnect sounds; how well it works.
In the second installment I will give a materials list and some details on how to prepare the materials. If that post is not too big I might continue on to the building instructions. Otherwise, the building instructions will be in a third post.
I wanted to create an interconnect from a clean piece of paper. I wanted to create as close to the ideal interconnect as I could, but at a reasonable cost! Of course the ideal interconnect would act as if it wasn't there at all. It would pass the signals from the source without any changes at all. It would pass the whole bandwidth of the source and it would not change the slopes of transients .….nothing.
The first goal was to reduce or eliminate the reactance of the conductors. In other words, I wanted to reduce the capacitance and inductance both to the lowest levels practical. It is the reactance that tends to colour the sound by changing frequency responses and introducing timing changes.
Second, was to use the minimum material in the conduction path. I have heard that too much material can cause some noise issues (whether this is true or not I'm not sure, but instinctively I felt that a minimal conductive material makes some sense).
Third, while keeping the material down I still wanted to keep very low conduction losses. This means low resistance. As you can imagine this constraint will mean a balancing act between the amount of material used and the quality of the material.
Fourth, I wanted to use the best materials available for the job, but without breaking the bank with costs.
Fifth, I wanted all the materials to be easily available. Something you can find in your home town and not have to send away for.
Sixth, I wanted to minimize any audio smearing due to any storage effect of the insulation. Therefore, I wanted to use insulation that has a low dielectric constant.
As you can imagine trying to meet all the design goals, while keeping it real world and reasonable requires some compromises. However, I tried to keep the compromises to a minimum.
When all is said and done I believe I have succeeded in meeting most of my design goals. I will allow you to decide that for yourselves.
Please don'’t think I have created anything earthshaking, I have looked at many interconnect designs and borrowed some of the best ideas that made sense to me, putting them together to meet my design goals.
The final product! :D
The interconnect is made mostly with materials you will find at your local hardware/building store and/or fabric store. The materials are of excellent quality, but do not cost a fortune.
Most important.….how does it sound! :D :D :D :D :D
This interconnect is the closest thing I've heard to a perfect interconnect. The moment I first heard it I thought, now I'm hearing all the music. I was blown away how effortless everything sounded. Even the very high frequency sounds were effortless and clean. With other interconnects, even when the high end is present and reasonably in control, the sound has either been strained and hard or soft and mushy. I heard more details in the music than every before. Each instrument or voice was clear and separate from all others. Transients (percussives) were fast and sharp, but totally natural without over-emphasis. Voices are clear and natural. The bass is tight but strong, but again not mushy or boomy.
Another first impression I had of the end product was I'm hearing the output of the CD player; without any changes or distortion. In other words I had the feeling that anything about the sound I liked, or didn't like, was because of the CD player (and the rest of the system) and had nothing to do with the interconnect. It was that clean. The same can be said for the sound staging. The sound stage seemed to be as good as the recording. For some CDs it was just average, existing between the speakers. For other, better, recordings the sound image went well beyond the speaker limits. In some instances the music gave that wrap around your head sense. Certainly the interconnects were not constraining the imaging in any way. Even for imaging the interconnects gave that effortless sense.
Compared to this interconnect every other interconnect I have tried seems “coloured” in comparison.
The transparency of this interconnect does not translate to “neutral” (or boring). The sound reflects the capabilities of the rest of the system and “feel” of the recording. With exciting and dynamic music that is what the sound was. With laid back or quieter music that is what you get.
Timing was also not a problem with this interconnect. The timing of the music came through unchanged and undistorted. If the musician “had it” you could hear it. If the musician didn’t have it, well you could hear that to.
Is this the perfect interconnect? Of course not. Is there room for improvement, I’m sure there is. But I’m thrilled with the end result of my experiments. I would suggest that this cable would be competitive with interconnects costing several hundreds of dollars but for a lot, lot less.
Next time … the materials and the preparation.
Questions or comments are welcome.
ROVA
 Post subject:
PostPosted: Sun Dec 14, 2008 1:01 pm
You've got my attention. I luv DIY projects!!
 Post subject:
PostPosted: Sun Dec 14, 2008 1:21 pm
Im all ears.. so to speak.
to me playing music .. even though badly recorded
is better than owning the best stereo on the planet
but it is nice to dream ..
PostPosted: Sun Dec 14, 2008 1:51 pm
Part 2 – The materials.
OK, to work.
The conductors for the interconnect come from CAT 5e Plenum cable. You will need somewhat longer CAT 5e cable than twice the length of your desired interconnect. Why CAT 5e plenum? CAT 5 cable uses OFC. Of course it likely is only 4N vs. 5N or 6N that most audiophile cables use but…..at what cost? It is important to use the plenum version of CAT 5e to get the required Teflon (FEP) insulation. Even so check the supplier’s specification for the cable via the internet. Not every CAT 5e uses FEP. In my case I got my cable from the local Home Depot and it had 3 pairs using FEP and the other pair was something else. The wire is 24 AWG solid copper, so this is keeping with my desire to minimize the conduction path material. I also find that the solid conductor does very well for higher frequencies.
The core for the interconnect uses ¼ inch diameter cotton cord. (Make sure it is 100% cotton.) Why cotton? Look it up on a dielectric constant chart (http://www.asiinstr.com/technical/Diele ... ection%20C) and you will see that cotton has a value of 1.3-1.4. This is even lower than Teflon at 2.0. Get more of this cord than you think you need, this will allow you to use the extra to help in the building of the cable. Note, do not cut the cord to length yet, leave it full length for now.
You will need some Teflon tape to wrap the cable. You can use the standard plumbers tape available at your hardware store. I could only get ½ inch width and that was fine. If you can get ¾ or 1 inch wide even better as it makes the wrapping process quicker.
You will need an outside jacket for the finished cable. I used what I had on hand. If you can get cotton shoe laces with the wider, tubular, lacing you could use that. Again, cotton should give excellent results due to the low dielectric constant. Since there is a coating of Teflon tape over the cable before the jacket goes on the jacket material is not so critical. Of course if you have a low dielectric constant materials available then use them!
You will need some short pieces of heat shrink to fix the jacket in place on the cable. You also need a couple of short pieces to lock the wires to the core at the start of the wire wrapping process (this will become clearer during the building instructions).
In keeping with the goal of using the minimal amount of material in the conduction path I used Eichmann bullet plugs. I do recommend them as they work well for me, but you can use whatever your favourite RCAs are. Although the bullet plugs worked well for me I did use some cheap “Source CC” RCAs in an earlier proto-type. This proto-type required some extra burn in to get good results and I’m sure the cheaper plugs did degrade the results a little.
Solder…I happened to have some silver solder so I used it. I would recommend silver solder but I don’t think this will make or break the project.
Packing tape. I use tiny strips of packing tape to hold the wires in place before getting the heat shrink in place. Why packing tape? Because the standard packing tape has a plastic base that is also a low dielectric constant material.
That’s it; nothing more exotic.
Except for bullet plugs you should be able to pick up the materials just about anywhere.
Wire preparation:
To make this interconnect you will need to separate the CAT 5e wires into individual strands.
First, strip the outer jacket off of one end. A short length of 3 – 4 inches is all that is required. You need to be able to get to the rip core (string in between the wires). Make a small slit in the jacket insulation on the end of the cable you just stripped. (This gives the rip cord a starting point to cut through the jacket.) Firmly grasp the rip cord in one hand a rip it down through the jacket of CAT 5e cable from one end to the other.
Now you can remove the jacket from the CAT 5e cable. You will now have four pairs of wires. Each pair will be twisted together. Identify which pairs have the appropriate insulation (FEP), these are the wires we will be using.
Now you have to untwist the wires (we need individual strands). I suppose there must be some quick way of doing this but…I didn’t use it. I just clamped one end of a pair of wires in a vice, stretched out the wire and then began untwisting. It takes a bit of time but it’s not too bad.
Now you need to straighten the kinks out of the strands. The easiest way to do this is to clamp one end of the wire in a vise. Take the other end in your hand and walk out until the wire is straight and suspended in the air between you and the vice. First, firmly but gently apply pressure to the wire (pull); not too hard but you should feel the wire stretch just a little bit. Now quickly ease the pressure off the wire (let it slacken a little) and then snap it tight again. Do this two or three times and you should have a straight wire. To ensure it was straight I went back to the end clamped in the vice and grabbed with wire with a cloth rag. I then walked back to the other end of the wire dragging the wire through the cloth in my hand. This pressure helps straighten any last kinks in the insulation. You can now roll up the wire on reels or what ever you have to wrap it on until you can use it,
You are now ready to start making your interconnects.
The next post may take a little longer. I am going to make a couple more cables and take some pictures to provide some illustrations for the text.
ROVA
PostPosted: Sun Dec 14, 2008 8:03 pm
Part 3 the construction.
Okay here we go….deep breath….and ready….begin.
Start with the cotton cord; this will be the core of the cable. Twist one end and add a small strip of packing tape to keep the end together and small.
Cut a small piece of heat shrink tubing about ½ inch long and slide it over the cord.
You are going to use 6 of the strands of wire from the CAT 5e cable and wrap them around the core in a helical pattern, three winding clockwise and three winding counter clockwise.
Three of the wires will be the positive wires that go to the positive (center) pin of the RCA connector and three will be the ground wires that go to the outside of the RCA connector. You should group these wires using the colour code. I chose to make all the wires containing white the positive wires. So I used white, white with an orange stripe and white with a green stripe, as positive wires. The three solid coloured wires were used for the negative wires. So again in my case I used the orange, green and brown wires for the negatives.
You need to feed the wires under the heat shrink and up past the end of the core. You need to leave enough wire beyond the core to attach the RCA plug. You need to add all six wires spacing them more or less evenly around the outside of the core. Not only that but you need to alternate positive and negative wires as you go around the core. For example, if you use a positive wire at 0 degrees you would place a negative wire at 60 degrees, a positive wire at 120 degrees, a negative wire at 180 degrees, a positive wire at 240 degrees, and the final negative wire at 300 degrees.
Why 6 wires? Or in other words why 3 wires for each polarity? Well mainly it is a guess. Remember I needed to balance the minimization of conduction material with the resistance. My first proto-type used only two wires per polarity wound around a polypropylene tube core. I thought the bass was a little lacking on this proto-type so I added a third wire on the next level. This sounded good so I stopped adding wires.
Next slide the heat shrink up to the end of the core being careful to keep the wires spaced evenly around the core. Shrink the heat shrink into place to lock the wires in position.
Next you need to clamp the end of this cable into a vise (or something similar) to support one end. In order to make sure the wires won’t pull out of the heat shrink while you wrap them; fold the wires over before you clamp them into the vise.
Clamp the wire in the vise.
Next you need to support the other end of the core far enough away to allow the interconnect to be wrapped. You can do this in any number of ways. I just put together something temporary.
Next you need to mark the core at 2 inch intervals with a marker or something similar. Mark every 2 inches until you have reached the length you want the final interconnect to be.
Why 2 inches, because it seemed to give the wire wraps a reasonable pitch. Again it is just a guess that seems to work out well.
Next you need to separate the three positive wires from the three negative wires. I kind of hook the negative wires back out of the way.
Now you begin the wrapping of the wires. I usually start with the positive wire that is closest to the top of the bundle as it is clamped in the vise. Begin to wind this wire around the core (clockwise or counter clockwise doesn’t matter at this point). You need to wind it one revolution each two inches so you end up crossing the mark you made on the core. Continue to wrap this wire around the core until you reach the final mark for your interconnect. Wrap one more turn around the core in roughly the correct position (this isnÂ’t critical). Try to hit the mark on every revolution.
Now take the next positive wire and begin wrapping it around the core in the same direction. You want to keep this wire spaced a little above or a little below the first wire (above or below will depend on which of the remaining positive wires you choose). Try to place the wire 1/3 of the way between the turns of the first wire. This is not critical so it is OK to “eyeball” it. Just make it reasonably close to 1/3 spacing.
Wrap the final positive wire in the same direction, hitting the space between the last two wires so that each is spaced about 1/3 of the distance from each other.
Next you are going to wrap the negative wires. Again pick a negative wire near the top of the bundle. However this time you will wrap it in the opposite direction to the positive wires. So if you wrapped your positive wires clockwise you need to wrap the negative wires counter clockwise. If you wrapped your positive wire counter clockwise then you need to wrap the negative wires clockwise. Again for the first negative wire try to hit the marks spaced every 2 inches.
Like you did for the positive wires add the final two negative wires, winding in the same direction as the first negative wire, keeping them spaced roughly 1/3, 1/3, 1/3.
You now have completed the wiring.
Why this pattern? Again this is a compromise trying to find the best configuration to reduce both the inductance and the capacitance. If you twist the wires tightly together they have a very small loop circuit and therefore the inductance is low. However the wires will be right beside each other and this will make the capacitance high. On the other hand, if you run the wires widely separated, but parallel, your capacitance will be very low but your circuit loop is big and open and hence the inductance will be high. Braiding the wires tightens the loops again and therefore lowers the inductance. However just like with twisting the wire, much of the time the positive and negative wires are close to each other and parallel to each other. This increases the capacitance again. With this helix wound pattern the positive and negative wires spend very little time in contact with each other so the capacitance is low. Although the circuit loops are a bit open they do still bend and twist back and forth over each other. This allows the magnetic fields of the wires to interact and the inductance is lower than if the wire ran parallel. As I said a compromise, but a pretty good compromise.
Next you need to cover the wiring with a layer of Teflon tape. This provides an outer layer of insulation as well as helps hold all the wires in place.
Begin by wrapping a couple of turns around the end that is in the clamp (I use a small strip of packing tape to anchor the Teflon tape to the cable). After you have anchored the Teflon tape with a couple of straight turns begin to use overlapping turns and make your way down the cable.
As you wrap you need to keep a little tension, or pressure, on the tape. You want the tape to deform around the wire slightly. Keep wrapping until you come to the final mark at the end of your desired interconnect length. Finish with two straight wraps at that point and then cut the tape off. You can use a small strip of packing tape again to hold down the end of the Teflon tape.
Clip the wires off leaving some extra length to finish the end of the cable.
You can now cut the core but do so a little way from the end of the taped area. You will need to add the heat shrink tubing before trimming the core to its final length. After cutting the core use a small strip of packing tape to point the end of the core like you did at the other end.
Now slide a second ½ inch piece of heat shrink over the wires and core. Shrink it into place locking the wires in place.
Now you can trim off the core flush with the end of the heat shrink.
You have now completed the cable itself.
Next you need to cut your outer jacket to length. (I cut mine so it would almost reach the end of the heat shrink tube but not quite.) You also need to cut a couple of pieces of larger heat shrink that will be used to lock the jacket in place.
Place the jacket over the cable. Feed the heat shrink tube over each end of the cable and jacket. Line up one end of the jacket about half way on the cable’s heat shrink tube.
Now slide the outside heat shrink right up to be flush with the cable heat shrink.
Shrink this in place.
Stretch out the jacket until the other end is about half way on the cable’s heat shrink tube. As you did with the first end, slide the outer heat shrink flush to the inner heat shrink end (while making sure the jacket doesn’t slide back). Shrink it in place and you have finished the cable itself.
Now you need to put the RCA connectors on.
Trim the wire on both ends to the appropriate length for the type of connector you are using. For the Eichmann bullet plugs I used that would be approximately ½ inches in length.
At this time you can strip the insulation off of each wire. You can also sort the wires into two groups. Place all the positive wires together and then place all the negative wires together.
Now twist the ends of the positive wires together. Twist the ends of the negative wires together.
Tin the ends of the wires (I guess with silver solder we should call that silvering?). Align the wires ready to solder to the plug and then trim the ends to length.
Solder on the plug.
Making sure you have put the shell of the plug over the cable first! :shock:
Complete the assembly of the plug and tighten the set screws on the shell. Voila, you are now done.
You are ready to enjoy.
Burn In: You may need to give your new cables a few hours of burn in to get the sound you want. With my first proto-type I didn’t like the bass at first but after a few hours (maybe 10 to 12 hours) the bass was getting better; as was the overall sound. With my second (and final) design I immediately had good bass. The interconnect sounded very good from the get go. Perhaps it has improved a little bit with time but it is hard to tell. Regardless, you might want to give the cable a few hours of running before you do your critical listening.
Potential problems: This interconnect has no outside shield. In high noise areas you may have problems because of this. I don’t, and I imagine most of you will not have any problems, but you need to be aware that this is not a shielded cable design. I would not recommend adding a shielding braid around this design as it will capacitively couple to both the positive and negative wires destroying some of the improvements obtained. The double helix winding pattern will provide a degree of noise rejection as noise induced on the positive lead will also be induced on the negative lead tending to cancel each other out.
Possible improvement: Some of you will notice I didn’t take all my design goals to extremes. Some of you would naturally ask couldn’t I have used silver wire. Yes, that would be a good idea. However that would conflict with the low cost and easy availability goals I set. If you want to improve the design by all means use silver wire. Using silver wire you might be able to go to only two positive and two negative wires rather than three of each. Also you would want to go to silver Eichmann bullets rather than the copper ones I used.
I hope I have made this clear enough for you to duplicate what I’ve done. If you do I think you’ll be happy with the results.
I would love to hear from any of you DIYers who make a pair of interconnects based on this design. I would love to hear how they worked for you. It would also be great to know how these interconnects compare to other commercial high-end products.
Anyway, have fun DIYing. :D
ROVA
 Post subject:
PostPosted: Mon Dec 15, 2008 2:09 pm
Very nice photos, you sure put a lot of work into this. As one who just completed braiding a tonearm lead (24 strand silk wrapped Litz wire), I see you and I are in agreement on some level, especially with regard to running the lengths across each other rather than the usual spiral.
The cable looks as though it's very stiff. Have you tried using a braid weave (over-under) to cross the wires and hold them to the core, rather than the teflon tape?
 Post subject:
PostPosted: Mon Dec 15, 2008 2:27 pm
Actually it is not all that stiff. I was surprised by this a little.
The braid weave might work just fine. However, I wanted a layer of good, known low dielectric, material between the wire and the jacket. This way you don't have to be quite so concerned about the composition of the jacket material.
As I suggested, there is always room for improvements. Why not try your way and let us know how it worked :)
Rova
 Post subject:
PostPosted: Mon Dec 15, 2008 2:48 pm
Hmmm....thanks. Will give this a try in after the new year when I have some time. Should be straight forward with the instructions provided.
 Post subject:
PostPosted: Mon Dec 15, 2008 3:16 pm
Thanks Rova,
Very well illustrated with excellent pictures. I'll try it out after new year.
I made some speaker cable using CAT 5 wire sometime ago with fairly good results.
 Post subject:
PostPosted: Mon Dec 15, 2008 4:16 pm
Thanks Rova,
Nice instructions and photos. I definitely want to try this, hopefully soon.
 Post subject:
PostPosted: Mon Dec 15, 2008 6:11 pm
Rova, nice work.....can this design be incorporated to a balanced interconnect, if so what would you add?
Thanks
 Post subject:
PostPosted: Mon Dec 15, 2008 6:21 pm
Great job Rova!!! I think I've got myself a project over the upcoming holidays. Thanks.
 Post subject:
PostPosted: Mon Dec 15, 2008 7:33 pm
Thanks
Actually I was wondering about that. The cable design is fully balanced as it is. I do not have experience with true balanced interconnects (XLR) but couldn't you just connect the positive and negative wires to the appropriate pins of an XLR connector? Must the XLR have a separate shield?
XLR guys help us out here please.
ROVA
 Post subject:
PostPosted: Mon Dec 15, 2008 8:52 pm
Hi rova. A cable dealer on cam(ultimate cable) mentions that since using cryogenically treated materials for making his cables, there was a significant improvement to the sound. Would you consider giving it a try for a new project. You might just end up with a top notch diy IC. A recent session of spk cables testing has shown me that diy cables are worth the investment in time & effort. The cables used were audience au24, diy cat5, & ultimate cables. Well, the diy cable came up on top beating the renowned au24. The ult. cable came in last but not by much. A good value for price cable. There's been talk lately that there's a loss of interest in 2 ch audio. I'm inclined to think that one of the reasons is that audiophiles are turned off by the amt of hype coming from the industry. Frankly some of the prices being asked for cables are obscene. You are doing a much welcome service to all those who refuse to pay these prices & who are going to try making their own as a means of helping themselves.
 Post subject:
PostPosted: Tue Dec 16, 2008 3:30 am
Rova wrote:
Thanks
ROVA
Hi Rova, I believe you are correct, I think it would need a shield.
Any suggestions, I have to build 2 sets, my current cables are too short. :D
