It is currently Thu Jul 19, 2018 9:11 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: Schiit Freya Users?
PostPosted: Mon Aug 07, 2017 6:34 pm
You can buy with the highest of confidence. Dealing with these guys has been nothing but joy. I ordered Freya and Gungnir multibit from them and received them in 2 business days.
Their equipment is simply spectacular! I have been traveling to many high end audio shows and have had the opportunity to compare different kinds of equipment. I can tell you that this tiny boxes, especially for their price, rival or if not better equipment 2 or 3 times the price.
To give you some examples, I was able to compare them between Mcintosh D150, C1100, multiple Simaudio products, NAD C510, Cambridge Audio, Rotel pre amps and I can assure you that none of these sound as good as the Freya-Gungnir multibit combo.
With all of the above mentioned equipment, I have noticed many types of musical nuances not even reproduced. I have also noticed that their volume controls produce such distortion that when you turn it up the vocal becomes so high pitched or nasal that is really harsh on the ears. I also heard some hiss even from balanced outputs.
Now back to our combo. First of Gungnir comes in multibit and make sure you get that one. You will hear such a DETAILED music reproduction you will start hearing musical details you never heard before in your songs. I mean this thing is so crazy I could hear breathing in the background or moving stools, etc. in some studio recording. I have played those songs MANY times on my D150 and C510 you don't hear it.
Highs are sweet and detailed, D150 doesn't play them as good. Vocals are warm and distortion free no matter what volume. Freya in passive mode is dead silent. If you want you can touch your ear to the speakers. Active JFET dead silent. Tube gain left hiss, right hiss and cracking. Emailed NT from Schiit Audio tech support he said to rearrange tubes in X pattern. Did it, no hum, no cracking, only the SLIGHTEST hiss. But you need to touch speaker hear it. Tight bass, warm vocal and sweet highs. Outstanding detail.
If you need more info let me know
PostPosted: Thu Aug 10, 2017 9:50 pm
That's quite a recommendation. This pre, and their new amp are on my radar. I'd like to see them reviewed, they really seem like the bang for buck is off the charts.
PostPosted: Thu Aug 10, 2017 11:47 pm
Can you please provide details on test systems you've used to do head to head comparisons with the gear mentioned? specifically the MOON pieces. A show is certainly not the place to come to these conclusions. I'd like to know a bit more.
PostPosted: Fri Nov 10, 2017 12:54 pm
Could any current user comment on the amount of heat generated by the unit? I'm considering ordering one, but it would have to be positioned about one inch away from my (vintage, with wooden panels) power amp on the one side and one inch away from the side of my pine rack/bookshelf, on the other side. Will the power amp and/or rack char, ignite or worse!? Never had a class A, tube or otherwise heat-generating unit before.
Also, is the clicking sound made when switching volume picked up through the speakers or is that just a localized mechanical sound?
My thanks,
Etienne
PostPosted: Fri Nov 10, 2017 1:35 pm
The clicking sound is just mechanical. I don’t hear it from 12 feet away when the volume gets loud.
