It is currently Tue Sep 25, 2018 10:31 am
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
 Post subject: Re: matched tubes
PostPosted: Tue Mar 28, 2017 12:03 pm
Paul,
Still working on that channel imbalance ?
PostPosted: Tue Mar 28, 2017 12:27 pm
I spoke with Art when I ordered them and he confirmed that they were matched.
As for microphonics, I believe that as I ordered the "AA ultra low noise" they would have been examined for microphonics. To be clear, I did not confirm or ask questions regarding microphonics, only matching.
BTW, I don't notice any noise on my Benz micro glider / Alphason / Oracle into the AI M3A Preamp into a YBA2 HCDT and Totem Mani2's. IMHO.
He also sent a few replacement gold coloured screws that I wanted to replace, without charge.
Its all about the music
PostPosted: Tue Mar 28, 2017 1:31 pm
sasquatch wrote:
Paul,
Check your pm Gary
PostPosted: Tue Mar 28, 2017 6:22 pm
dtsaudio wrote:
When it comes to small signal tubes matching can give you better channel balance, but is not usually necessary. It depends on the circuit whether audible or not.
It is usually better to match power tubes, at least matched per channel. This is most important if there is not individual bias or the tubes are cathode biased. If the tubes have individual bias, matching becomes less important, however for maximum power and performance matching is always better.
Tubes typically have a fairly broad measurement tolerance, so just because they are the same tube, they could be as much as 20% - 25% off from each other.
How important is it to 'match' power tubes when using an amplifier with 'fixed bias' that you adjust yourself?
Trust I'm using the right terminology.
I Put A Spell On You!!!
