It is currently Sun Jul 15, 2018 6:54 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject:
PostPosted: Sat Aug 02, 2008 7:45 am
Itsnotluck wrote:
Can someone help me locate a quality 90 degree IEC plug?? I have to stuff my projector into an ottoman and I need clearance at the back.
partsconnexion
http://www.partsconnexion.com/PDF/schurter-70447.pdf
[ DIY Audio Projects ] ::: [ Hi-Fi DIY Audio Projects Blog ]
 Post subject:
PostPosted: Sat Aug 02, 2008 11:52 am
try this site
http://www.takefiveaudio.com/mall/shopc ... p?type=diy
I built their star quad powercords for my cd andtube amp. I think this is a John Risch design.
It had an enormous effect with the cd, much less so with the tube amp (I think because of the power transformer, which acts like a filter because of its inductance (Im not positive about this))
Anyways, highly recommended.
best,
Perry
 Post subject:
PostPosted: Sun Aug 03, 2008 6:41 am
Thanks gmilitano! That be the perfect one... :D
 Post subject:
PostPosted: Sun Aug 03, 2008 6:48 am
You are welcome. I have ordered from them several times and they are good.
 Post subject:
PostPosted: Sun Aug 03, 2008 10:47 am
it's probably not worth your time. you can buy these furutechs cheaper than it costs to diy. http://www.6moons.com/audioreviews/whit ... ine_2.html
they come in all types of connectors too. i got mine from lawrence at excel stereo.
 Post subject:
PostPosted: Sun Aug 03, 2008 3:57 pm
Those furutech cord are incredibly cheap.
In fairness to the diy idea, the patio cord that he compared them to is not likely to be as good as the belden cord used in the takefive cables I built.
That said, those cost me about $70 a piece to build, so the price on the furutechs is very attractive!
 Post subject:
PostPosted: Sun Aug 03, 2008 8:13 pm
The quality of the Furutech product is second to none.
UNITY AUDIO
 Post subject:
PostPosted: Mon Aug 04, 2008 12:07 am
i have made my own diy power cords out of kimber 4tc and hubbells. these furutechs crush them. very clean extended, well organized sound.
 Post subject:
PostPosted: Mon Aug 04, 2008 8:34 am
You can DIY better quality for less than the furutechs. For instance, those cords are 90$ and not shielded. You can DIY to your own length, finish, color, connectors ... Depends on how you value you time.
 Post subject:
PostPosted: Mon Aug 04, 2008 8:40 am
I think they were referring to Furutech parts, not the assembled cables.
I know I was....... the FI11 are $35 each for copper, and not much more for gold or rhodium
Mind you, if you were assembling a cable with a C7 connector, those are kind of hard to find as a DIY part......
UNITY AUDIO
 Post subject:
PostPosted: Tue Aug 05, 2008 10:03 am
Since their is lots of good direction with cables on this thread. Can someone join in with a good DIY power bar project. May be with up to six
receptacles and no power conditioning.
Thanks
 Post subject: Powercords and IC's
PostPosted: Tue Aug 05, 2008 12:34 pm
another DIY power cord ....
http://www.audiotweaks.com/diy/bobcrump_pc/page01.htm
and, for Itsnotluck, a power bar ..... sorry, only 4 outlets
http://www.audiotweaks.com/diy/ac_outletc/page01.htm
and, maybe a power conditioner ......
http://www.10audio.com/diy_power_conditioner.htm
 Post subject:
PostPosted: Tue Aug 05, 2008 1:39 pm
Thanks Palmerston!!
Can anyone explain series wiring or parallel Versus star wiring.
I've also heard the terminology " star grounding" used as well.
What would be the benefits ?
