It is currently Sun Jul 15, 2018 1:02 pm
Post new topic Reply to topic  [ 16 posts ]  Go to page Previous  1, 2
PostPosted: Mon Jun 05, 2017 11:44 am
OBI56 wrote:
Here is a scientific fact for you: Rubber - most rubbers are probably resistant to alcohols, but prolonged exposure WILL cause loss of elasticity. Its not the immediate effect that you have to worry about, its the long term effects.
True dat.
I meant to say that denatured alcohol can be used on pinch rollers etc. but it's definitely not a suitable long-term substitute for a proper rubber cleaner and conditioner. If you do have to use it in a pinch (pun intended...), use it sparingly and don't over-saturate the cotton swab when cleaning rubber surfaces. Then use a clean cotton swab to wipe off any excess alcohol; never allow it to dry if possible.
