It is currently Fri Aug 17, 2018 10:16 pm
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: finger nail oil...
PostPosted: Fri Jun 10, 2016 11:53 am
ripblade wrote:
You mean nail polish? Yeah it's probably why so many women are nutso lol.
Have you tried Locktight instead?
Yeah, I know HD has locktite something...she bought some nail polish thing and does not like the colors and dumped to me, and I figured to make use of it. Works fine, but really smell terrible.
I strictly prohibit her from using nail polish on my daughter...from the smell I can tell is poisonous, and kids tend to find a way swallow anything...
PostPosted: Sun Nov 19, 2017 11:20 am
BAF2017, some friends were expecting sort of ACA "2.0"...turned out to be ACA 1.1, some are "disappointed", some are "confused"...so, what's the deal with ACA 1.0 to ACA 1.1?
What have been changed?
-Circuit-wise: Comparing with ACA 1.0 (with R15 - 2.21K which added later on), there is only ONE change to the circuit, i.e. 68.1K (R12) resistor changed to 39.2K. That's it.
-Above change is tiny, the circuit looks almost the same, what about PCB layout...well, to allow "shorter" inner height chassis, 2 IRFP240 MOSFETs moved to sides, now it looks different....LOL
Simply put, if you already have an ACA with R15 patch, what you need to do is to parallel the 68.1K resistor with another resistor around 68.7K then you have upgraded to ACA 1.1.
Should I upgrade? ACA 1.1 has less output power, and higher current...well, I have attached a bigger picture below...lower noise, more damping factor, more flat curve and etc...
Now should see that ACA 1.1 is better specs-wise, but will ACA 1.1 sound better? I don't know yet...but it will be fun to play. Enjoy!
 Post subject: Re: Pass ACA Builds
PostPosted: Wed May 09, 2018 5:00 am
Building an ACA for my friend...will pass to him this weekend on our trip to Ottawa...
Gosh...hope I can finish it in time...
PostPosted: Wed May 09, 2018 5:14 am
I just noticed they are now up to ACA 1.6 and they are now taking orders for July delivery. Looks like a spectacular piece of kit!
¿lɐɯɹou ǝq ʎɥʍ
PostPosted: Wed May 09, 2018 5:43 am
It's diyaudio ACA kit 1.6...not ACA 1.6 (ACA is Pass's design)...there is a difference;-)
Let's play some Aluminum Oxide Ceramic (1mm thick)...a bit overkill here...chilly
File comment: Aluminum Oxide Ceramic
PostPosted: Fri May 11, 2018 4:39 am
"Painful" metal works...two of the holes are not round holes...
File comment: Nail polish...
PostPosted: Sat May 19, 2018 3:47 am
Done and delivered last weekend... :)
PostPosted: Sat May 19, 2018 4:02 am
Setup and running....alongside "Frank Wang" ACA monoblocks and crossover. Thanks again Yaping.
PostPosted: Sat May 19, 2018 4:51 am
Hi palladio,
Are you using a stereo version plus two monos into the same speakers, via the external crossover? What speakers are you using?
PostPosted: Sat May 19, 2018 5:28 am
I am running DIY Open Baffle. Visaton B200 and Eminence Alpha 15. Crossover is at 250HZ. Tweeter is Vifa D27TG-35 with back removed, 1uF cap. The monoblocks run the top end and the second Amp runs the woofers. I am very pleased with this setup. Note: Listening is 90% classical and I prefer moderate sound levels. Frank does beautiful and meticulous work, I build his speaker boxes and he builds my electronics. Love being part of the CAM community!
PostPosted: Sat May 19, 2018 7:03 am
Nice setup!
What's the crossover?
PostPosted: Sat May 19, 2018 7:38 am
Frank, your metal work skills are great, this would help.
https://www.princessauto.com/en/detail/ ... -p2910254e
PostPosted: Sat May 19, 2018 7:43 am
yup, or if yer already loading the chuck on the press consider step bits
however you do get what you pay for... link just an example.
https://images-na.ssl-images-amazon.com ... L1001_.jpg
PostPosted: Sat May 19, 2018 5:31 pm
Thanks Gents...those 2 holes for DC inlet are not round holes, have to use a file
-- 20 May 2018 01:43 --
Hear, hear...the most "fun" part in CAM community is getting to know friends like you...and the pleasure is all mine.
PostPosted: Tue Jul 24, 2018 3:14 pm
Got an email from diyAudio this morning informing me of a shipment, complete with tracking #. Turned out to be for the chassis that arrived 3 weeks ago. :lol:
Anybody get anything else? Like the boards, parts etc? Something that looks like an amp lol?
The time is approaching.... 8)
