It is currently Tue Aug 14, 2018 8:57 pm
Post new topic Reply to topic  [ 63 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Pass ACA Builds
PostPosted: Sun Sep 13, 2015 6:44 am
Clean up PCB with Isopropyl alcohol - bought from local Pharma Plus store.
-Use a little brush, e.g. tooth brush, clean PCB with alcohol;
-Wash off alcohol and other residual with water and brush...;
-If one above clean & wash is not enough, dump used alcohol and use clean alcohol repeat above 2 steps
-Wash & clean, don't soak PCB and parts in alcohol
PostPosted: Sun Sep 13, 2015 8:01 am
Youre a hell of a good builder. Just from the look and attention to detail its clear that your builds are of the highest quality. Someday im gonna have to contract you to do a 2 channel for me lol
PostPosted: Sun Sep 13, 2015 5:57 pm
Thanks Bksrt8, I believe you are a good builder yourself;-)
After some DIY projects, things will become natural, such as where to use higher soldering temperature, and where to use low/normal temperature, it's just a matter of experience.
PostPosted: Sun Sep 20, 2015 11:08 am
Got the chassis, and made some progress today...
-Position PCB on sink to drill the holes for supporting PCB, then tapping...;
-Mount PCB, and then position IRFP240;
-Drill the holes and tapping for IRFP240 holes;
-Assemble PCB to sink, Put in IRFP240, tighten all screws...and then solder them to PCB...
PostPosted: Sun Sep 20, 2015 11:18 am
Very nice, would like a couple mono blocks for myself.
I can make soup. No solder involved though I have used gold flake in a Consommé.
PostPosted: Sun Sep 20, 2015 4:39 pm
Give ACA another Isopropyl alcohol bath after soldering IRFP240, will left them lying there for a couple of days to dry naturally...
The rest are wiring, final assembly, power up and adjusting ...
-- 21 Sep 2015 00:41 --
You know what, sometimes I feel DIY is kind of like cooking, use some of this, some of that....next time change some ingredients to see if can get another "flavor"... :)
PostPosted: Sun Sep 20, 2015 7:18 pm
whats your impression of the ACA vs some of the other amps you've built or heard?
What speakers do you use a 5W set on?
PostPosted: Mon Sep 21, 2015 5:22 am
I use ACA to drive DIY Zaph SR71, 85dB 2-way bookshelf speaker, for desktop close range listening...some of my friends use it to drive even bigger speakers
ACA is warm sound, a bit like tube amp...
PostPosted: Sat Oct 03, 2015 6:52 pm
Powered up, adjust bias...
Drilled LED holes on front panel, washed front panel with Isopropyl alcohol to remove any grease and dirty stuff...apply metal sticker to honour Ms. N. Pass
PostPosted: Wed Oct 07, 2015 7:45 am
My "Frankbuilt ACA Monoblocks" drive the Visaton B200's in my open baffle setup. This sounds very fine to my taste.....classical music at reasonable levels in a medium sized room.
PostPosted: Thu Oct 08, 2015 5:13 am
oops, busted ... :)
A new frame for you OB?
PostPosted: Thu Oct 08, 2015 6:54 am
Yes....simplifies the whole setup. Single Eminence Alpha 15 no tweeter. Visaton running full range.
As soon as I get the basement bathroom/laundry room done i will start your TG Seas 3-Way classic..... :)
PostPosted: Thu Oct 08, 2015 5:17 pm
No rush, my friend...love your wood stain color of the new OB;-)
PostPosted: Tue Oct 20, 2015 6:51 pm
Done...
-- 21 Oct 2015 03:05 --
This should be the last ACA I will build this year...need play something else;-)
PostPosted: Tue Oct 20, 2015 7:10 pm
I just replace two chips in a phono pre and i found that to be a pain in the butt.
Nice work.
A 'no' for you is sometimes a 'yes' for me.
