It is currently Fri Jul 20, 2018 10:30 am
Post new topic Reply to topic  [ 406 posts ]  Go to page Previous  1 ... 24, 25, 26, 27, 28  Next
 Post subject: Re: What are you DIYing?
PostPosted: Fri Mar 24, 2017 1:00 am
Winter_vinyl wrote:
Canvas, since I'm good for audio - for the moment:
Nice work!!
PostPosted: Fri Mar 24, 2017 7:51 am
analogluvr wrote:
Nice work!!
Thanks, semi-retirement has its perks, like time for music and painting.
"Just remember: For every mile of road, there's two miles of ditch."
- Doug DeJarlais
PostPosted: Mon Sep 25, 2017 3:41 pm
A record crate built with Ikea mattress support wood things. Slats is the word ...
The ones with the fabric ribbon holding them together.
I added some old angle irons to the corners.
PostPosted: Mon Sep 25, 2017 5:50 pm
Slate Garrard 401 project......
Cheers
FM
PostPosted: Tue Sep 26, 2017 5:34 am
Cheers
FM
WOW
DEEPLY impressive
PostPosted: Tue Oct 24, 2017 11:23 am
DIY 120" Projector Screen
-- 24 Oct 2017 13:26 --
Lenco L75 Rebuild
PostPosted: Tue Oct 24, 2017 12:00 pm
s2kov wrote:
[b]DIY 120" Projector Screen
Very nice. Good idea on the LED back light. Are the colours changeable?
PostPosted: Tue Oct 24, 2017 1:56 pm
s2kov wrote:
Could you kindly provide more information on how you created the screen? What is the material of the screen and the border and how did you tension it?
PostPosted: Tue Oct 24, 2017 2:25 pm
Yes, LEDs are changeable.
PostPosted: Tue Oct 24, 2017 2:43 pm
Screen material is blackout cloth with 2" black felt tape.
Refer to this https://www.flickr.com/photos/s2kov/albums on how i did it.
Demerara wrote:
Could you kindly provide more information on how you created the screen? What is the material of the screen and the border and how did you tension it?[/quote]
PostPosted: Sun Dec 03, 2017 9:51 pm
Its hard to tell much from this but basically a plywood aquarium. Internal dimensions are 72"x32x30 - approx. 300 Gallons. Sitting on a real strong stand and will be made water tight. Big filteration, custom lighting... big job lol
PostPosted: Mon Dec 04, 2017 5:48 am
Good morning all, I finally added a second arm to my custom VPI turntable. I will be running a dedicated mono cartridge. It is a custom plinth that I had constructed veneered with Macassar Ebony. Now I am on the hunt for a mono cartridge.
PostPosted: Mon Jan 01, 2018 7:01 am
PostPosted: Fri Jun 22, 2018 3:24 am
Just finished diy cabs (not pretty but built like a proverbial tank), dropped in new Audio Nirvana Classic 8+ full range drivers,
and 'gobsmacked' doesn't begin to describe my first impressions. I have owned ALOT of sub $5K speakers in my time -
(Linn, A/R, Avid, Rogers, Dali etc.), and these absolutely blow them all out of the water and keep sounding better as they break in.
Amazing with Schiit Saga pre and Cary SLA70 amp. HIGHLY recommended, can't say enough...
PostPosted: Fri Jun 22, 2018 4:05 am
Well, here are some parts I made for light fixtures.
Sadly, I no longer have assess to a metal lathe.
