It is currently Fri Jul 20, 2018 8:16 am
Feedback for dealers regarding experience OUTSIDE of CAM must go in the Dealer Feedback Forum.
PostPosted: Tue Jul 31, 2012 1:42 pm
Money was exchanged, MODs speak up.
I remember this topic...
http://www.canuckaudiomart.com/forum/viewtopic.php?f=2&t=25441
www.leohl.ca
PostPosted: Tue Jul 31, 2012 2:02 pm
viktorus wrote:
Thanks for reply, could you clarify pls who is "cam"? (I don't know many people here...)
Thanks!
cam, or more correctly CAM, is an acronym for Caunuck Audio Mart. The poster was suggesting that you contact CAM or Canuck Audio Marts administrators or moderators, in hopes that they will be able to facilitate a satisfactory resolution for you.
PostPosted: Tue Jul 31, 2012 3:09 pm
Report a problem with the ad, leave negative feedback or contact the Mods directly at moderators@canuckaudiomart.com if he wishes to pursue his $50.00 refund. What more needs to be said?
Those who live by their wits are obliged to live beyond their means.
PostPosted: Tue Jul 31, 2012 3:11 pm
Oooops. Angus beat me to it.
PostPosted: Tue Jul 31, 2012 3:32 pm
yournamehere wrote:
akanrg wrote:
yournamehere wrote:
Live and learn, shop elsewhere next time.
This reply is not helpful to the OP or CAM :shock:
Yeah, OK. In a situation where no satisfactory solution seems likely, what is the solution?
Advise the OP to continue on the same path, with same complaints, or suggest a wholesale change in thinking?
Buy used from a dealer with a warranty, where you can go and see the piece in use.
So many sob stories, but do the same thing over and over?
30 yr old gear?
I agree with YNH, the thing is 30 years old...again, when you buy used gear, you get used gear! Hell, some new gear break all the time!
Joe Bonamassa, 2014
PostPosted: Tue Jul 31, 2012 4:15 pm
Everybody, thanks for your opinions and advices.
I'll send a message to admins as suggested.
Thanks a lot.
-- 08 Aug 2012 20:20 --
Sent all details to moderators.
Waiting for their response [if any].
Thanks everybody.
