It is currently Thu Jul 19, 2018 1:35 am
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3
PostPosted: Mon Feb 01, 2010 10:10 am
stereoitis wrote:
Can the parts be bought seperatly so that an individual could incorporate this into their own custom rack?
Not that I aware of but I can ask. I gave you an picture of the method, you should be able to DIY it, but getting the right combo mounted, might be a bit tricky. Also you would need to figure out how to keep it in place.
I have a record clamp with a level meter built in and every TT I have dropped on it self leveled, not sure how that worked, but it did.
Ian
The trouble with jogging is that the ice falls out of your glass. - Martin Mull
http://www.grantfidelity.com
Meet us at Montreal SSI 2010, March 25-28th, Suite 2326 Hilton Bonaventure Hotel
Meet us at AKFEST, Sheraton Detroit Novi, May 1-2, 2010
PostPosted: Fri Apr 08, 2016 8:43 pm
Mounted my vpi scout on a 50 pound sand box ,sitting on a shelf mounded on a load bearing wall.
Also mounted my tube phono preamp on a smaller sand box sitting on shelf made of one inch rubber sandwiched by 3/4 inch mdf ,also hung off load bearing wall,line stage on same shelf on rubber pad.
